samjepperson's Avatar
Leaking Auxiliary Air Regulator (AAR)
I just completed a smoke test of my 82 911SC to uncover some minor CIS issues and found three leaks; 1 Cylinder Fuel Injector (easy fix), around base of pop off valve (more complex) and around the body of the AAR (was not from the hose connections).
Based upon some searching it looks like these AAR can be rebuilt/cleaned by drilling out the rivets and replacing with bolts. My concern is that the housing is leaking between the two halves at the seam...is there a seal that can be replaced or do I need to find a new one? Maybe take apart and put back together with some sort of sealer?
Part # 0 280 140 218.44
All Long Hoods, 2002 TT, 1992 968, 1999 SPB, 2004 C4S gone, but not forgotten
1982 SC - Grand Prix
Old 04-30-2024, 08:13 PM
Alan L's Avatar
Yes you can drill rivets and replace - 4mm bolts I think.
Cant remember if there is a seal in there or not - but RTV would do it. There may be a thin section O ring. If so you could make one - get a larger circumference one of same thickness and cut to size.
If you really want to get picky, slice the ends at 45 deg and overlap. Done.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 05-01-2024, 12:01 AM
Thanks Alan for the reply. Since this part gets warm from the engine, what type of RTV would you recommend? Glad to see this might be fixable without spending a fortune on a new one or take a gamble on a used one.
Old 05-01-2024, 07:25 AM
The two halves are sealed with an o-ring. My AAR was leaking at the electrical connector. There is no seal installed there.
Old 05-02-2024, 01:38 AM
Alan L's Avatar
It doesn't get that warm/hot. If you can't get an O ring to fit, black RTV would be fine - good to around 100 Deg C. It won't be that hot.
But the leak will prob be quite small, so the other benefit of cracking it open is to clean all the gunk off the sliding valve. Then you can get in there anytime you need later.
Regards
Alan
Old 05-02-2024, 12:55 PM
E Sully's Avatar
Here's a thread on the AAR which will show the internals.
AAR Revisited
Ed
1973.5 T
Old 05-03-2024, 10:57 AM
I took the AAR apart and found that the o-ring broke which left a gap...this was the cause of the leak. Could not find an appropriate replacement so decided to leave it as is and re-seal carefully with RTV. Hopefully this will solve the leak.
Old 05-05-2024, 07:19 AM
Alan L's Avatar
You would be better to get a longer O ring, of same section, and cut to size. They are just O rings , after all.
That looks very clean in there. Must have a cleaner running engine than mine :-)
Alan
Old 05-05-2024, 11:55 PM
