911SC '82
front Apron, is it primed?
I purchased the JP Group Dansk Apron without fog lights holes because i want to delete them and have a cleaner look.
I received it today and it’s all satin black, but not deep glossy black as my 911SC black paint (i think L041) Is this supposed to be primed or do i have to prime it again if i wanted to make it the exact black? Thanks |
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
911SC '82
gotcha thanks!
Instagram: @TuitTech |
I replaced mine about 20 years ago, but had it powdered painted to match the body color before the install. It's held up pretty well after 100,000+ miles.
Your right my bad didn’t realize that was dipped in ecoat.
911SC '82
I have two cans of primers at home Rustoleum Self-etching and a Rust-Oleum 249321 Primer Sealer, is the latter what you mean? |
A red scotchbrite or some 400 dry just to give some tooth for mechanical bond. I’m sorry I misinterpreted your post you probably should shoot an epoxy primer over ecoat then your paint after epoxy flashes. Don’t use rust oleum use the right paint. You don’t need glasurit just a decent epoxy with hardener followed by your base coat clear coat or single stage. If you must use rust oleum at least add some hardener to it.
911SC '82
a primer like this?
https://www.amazon.com/Eastwood-Epoxy-Primer-Spray-Aeroso/dp/B07Q5G8STD/ |
Correct process would be
Sand 220 1 coat of epoxy Depending on brand you’d have to check “rules” With SPI I would wait 24 hours 2 coats of Wurth SkS 1 coat SPi epoxy reduced as sealer Base Clear
911SC '82
Idef I'm curious to di this process myself. also this piece is not going to any car show so id be ok to have something I can have fun to do myself. newbie question: can I sand it with a rotary sender? if I understand correctly: 1 coat of expoy, 2 coat Wurth SKS then AGAIN 1 coat of epoxy? what do you mean reduced as sealer? |
I'm good with tools.
I'll jump in having done a bit of painting. I personally would not use a rotary sander. I would sand it by hand. Your just giving the part a surface that will allow the primer to bite into. I would be afraid of taking too much of the surface off with a rotary.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
911SC '82
got it thanks!
Don’t forget to degrease before sanding, also use a tac cloth to remove dust before primer
69 911 rust bucket project @le_mackerel 356 stuff @crazygreg |
911SC '82
ok, i sanded it with 220 by hand, very lightly, the current paint is def very light as you can some small edges lost the paint and showed a bit of metal below. I'm glad I didn't use the power sander.
now, to recap which epoxy spray can I use? any amazon direct link so I don't make mistakes? |
911SC '82
thanks! |
