Factory imperfection or repair? 911 3.2
Hi everyone,
I'm looking at a 1987 911 3.2 for a friend of mine. I've noticed some irregularities on below the A-pillar near the A/C vents (next to the top hinge for the door) on one side. There's a section there that is black steel and not covered by vinyl. My friend seems to think it's just a factory imperfection. I think it's not. Is anyone able to post up some photos of their car? Ideally a 1987-1989 with no accident history to see if this is how they are, or if a repair has been done. Surely it's not how it left the factory? I've had a look at a few photos online and the area looks very inconsistent between cars, so I'm not sure.
Not sure if this is factory?
This side looks factory though:
Old 03-28-2024, 02:42 AM
Looks like factory.
Here is a pic of mine. 88 Coupé. Same interior color by the way.
Gilles
RoW 88 Carrera coupé
Old 03-28-2024, 03:24 AM
Originally Posted by wazzz View Post
Looks like factory.
Thanks for that. I should have specified. That looks factory 100%. It's the other side I'm not sure is. You can see in the second photo it looks very different. Does yours look the same on both sides?
I had to do a double take. I thought you posted my photo again, because both the exterior and interior colours are the same!
Old 03-28-2024, 04:04 AM
Sorry can't take a pic of the other side at the moment. Car is parked in garage against right hand wall and under interior cover, so I cannot open right hand door.
Gilles
Old 03-28-2024, 04:15 AM
(man/dude)
Jonny042's Avatar
These cars were hand assembled at the factory and are pretty imperfect, especially in that area which is poorly finished.
I wouldn't be concerned about that. I'd be more concerned about the door hinge bolts having been repositioned at some point...
Post a link to sale and we could all give you our two cents...
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 03-28-2024, 04:44 AM
I just looked at my '87 and frankly it doesn't look much different on the passenger side.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 03-28-2024, 05:02 AM
Behind the Sun
Fritz or Otto were getting ready for lunch break
Old 03-28-2024, 05:52 AM
cycling has-been
bkreigsr's Avatar
Did the rest of the production cars use spot welds on that pillar?
On the right side only?
Old 03-28-2024, 08:54 AM
I wouldn't be concerned about that. I'd be more coerned about the door hinge bolts having been repositioned at some point...
It is not advertised yet. So have very limited photos, will be heading back there this weekend, so can take and post up some more pics though.
Surely it can be that bad though. There's even a jaggad edge that has pierced the doors weather strip, see below a close up.
Old 03-28-2024, 11:47 AM
As in neat like the bottom picture, or rough like the too one?
Old 03-28-2024, 11:49 AM
That's been worked on!
Old 03-28-2024, 12:04 PM
Still here
pmax's Avatar
No way that's factory.
Old 03-28-2024, 12:06 PM
That's what I thought, but a few photos online show the area to be very rough. Both sides aren't usually consistent.
Old 03-28-2024, 12:09 PM
PCA Member since 1988
It appears to me that the hinge bolts have been repositioned and repainted.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-28-2024, 02:01 PM
Not too concerned about the hinge bolts. That side of the car looks ok. More interested in the section where it doesn't match the other side.and trying to figure out if it was just missed at the factory, or if it has been tampered with. If anyone has some more photos that would be great.
Here is another angle if it helps.
I've had a look at some photos online from an 1989 911 with 6k miles and it looks, not amazing, but the pictures aren't close up, so cannot tell unfortunately.
Old 03-28-2024, 04:22 PM
For reference. 1988 911 coupe.
Old 03-28-2024, 05:18 PM
That makes me think it's been repaired. I don't know how good quality was back then.
Old 03-29-2024, 03:42 AM
Going to see the car again tomorrow. Anyone think it's factory?
Old 03-30-2024, 01:11 AM
Pictures from my 87. Hope it helps
Old 03-30-2024, 06:47 AM
i don't think that is factory. i think that damage happened after. not a hard fix and i wouldn't let it detract me from buying it if i liked the car. good luck and let us know if you find any more information.
Old 03-30-2024, 08:42 AM
