Removing engine tin by the fan with engine installed. Possible?
Want to remove the engine tin that runs parallel to the cooling fan (the long section below the saddle) from the engine with the engine in the car. It looks like it's possible but am not sure. Do you know if it is or isn't?
Muffler off, then it comes out the bottom.
That's not objectionable. Thanks John :)
| All times are GMT -8. The time now is 07:54 PM. |
