@porscheprojekt
Spring Plate Angle Confusion
Hello everyone. I've just reassembled my rear suspension on my '68. I've put a 2.7L in a 912 body and have 24mm torsion bars w/ Koni shocks. For my stance, I'm trying to have my rear wheels just creep up into the wheel wells. After using the Elephant Racing Spring Plate Angle Calculator, I've arrived at an angle of about 29°.
Here's my issue... I have to set my spring plate angles at 15° to get that ride height! I've triple checked the size of my torsion bars. This being my first ride adjustment on a SWB Porsche, I imagine there must be something I'm doing wrong. Additionally, everything squeaks when I put weight on the back of the car. Is this a related issue? Any help would be greatly appreciated. I've attached a few pic (Please disregard my boy's head in the pic of the whole car!) Thanks! Jeff ![]() ![]() ![]()
'68 912 body 2.7L engine Solex Cams Weber Carbs SSi Heat Exchangers / Monty Muffler 2-in/1-out |
That's going to be a fun car! No need to excuse your son, that's a great photo. He's going to have some great memories. And that engine is gorgeous.
Are those the Pelican heater blower delete plates? So to your spring plates - that looks fine. Quick question - when are you measuring 15 degrees? I ask because that sort of looks like the angle you have in the photo with the suspension compressed. The Elephant calculator is for the spring plate in full droop, before you set the car down. Mark
1979 911SC Targa Last edited by Mark Salvetti; 05-19-2024 at 08:31 AM.. |
PRO Motorsports
The discrepancy lies in what the ride height on their calculator actually is.
For example, actual Euro ride height is much higher than people think it is. The commonly held idea is that Euro height results in fender lip measurements of 25.5” front and 25” rear with a 25” tall tire. But if you set it to factory Euro specs it’s actually 1” higher than that. Other factors at play are gas pressure of the shocks that have to be taken into account, and the rubber control arm and spring plate bushings that will settle about 1/2” after driving.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
