911SC '82
Question How to tighten the handbrake/ parking brakes
I noted that my parking brake is effective only when I fully pull it all the way up (didn't count how many clicks) but it seems a lot/ too much compared with my memory of previous cars I drove. also my light doesn't lit up when I pull the brake so while I'm there (I also need to replace the heater cables) I wonder it this ca be adjusted at the lever side or do I need to work on the wheels
this post seems to imply both but is not for 911, so I wonder if there is a similar guide for 911
thanks
https://rennlist.com/forums/diy-964-1989-1994-911/207593-howto-checking-and-adjusting-parking-brake.html
Old 05-26-2024, 08:15 PM
walt's Avatar
Here is the procedure for the SC. Fairly straight forward, get a good flashlight with a tight beam to help find the sprockets.
https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/50-Parking_Brake_Adj/50-Parking_Brake_Adj.htm
Walt
82SC 3.0
81SC 3.6
Old 05-26-2024, 08:34 PM
911SC '82
I was looking at that, but not super clear the second photo... no idea what am I looking at there...
Old 05-27-2024, 01:48 PM
