Does it fit G Body 3.2?
Hi,
Just looking to Purchase this unit from a guy who found them in a storage unit. Do you think this setup of SSI header and muffler fit on later G body 3.2? Thank you, ![]() ![]()
Yes. Those are 3.2 exchangers
Thank you, overall are they good for street use?
Yes, a little more power than the stock exhaust and nicer sound. I've been running them for years.
If you live where emissions check and catalytic converter is required, you won't pass inspection. Technically you should change the chip in your ECU to take maximum advantage, otherwise it will probably run lean at wide open throttle. |
Thank you, yes I am in CA and will need to get the smog and switch later. Is chip plug and play? any particular brand?
Cars and Cappuccino
Steve Wong
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
I used to switch exhausts between stock and SSI when I lived in California and Colorado. It's not that hard once you get past removing the exhaust manifold nuts the first time.
Contact Steve and he can supply a chip that is appropriate for your exhaust configuration. After installing it, take it to a dyno, get A/F ratio data and send it to him. He can then revise the chip to to optimize it for your car. |
