911SC '82
I just got a new Danks Sport muffler and two new straps by URO (90111115704)
but the straps seem too short, or maybe I am doing something wrong... I cannot find any specific straps for this muffler... did anyone have the same issues? code 90111115704 brings up the same exact straps everywhere... the only different ones are https://www.pelicanparts.com/More_Info/90111115704.htm it seems they have a longer bolt?? |
A longer bolt is often the ticket.
911SC '82
Had the same problems a couple of weeks ago. I ordered 2 left side straps for a 3.2 which are 58cm instead of 51cm. No problem anymore!
Jesse '76 911 backdate with Carrera 3.0 engine |
Just went through this myself.
Ordered the correct straps. The 'short' one is just long enough. The 'long' one needed an extra looong bolt. The straps were supposed to be stainless and came in Dansk bags. One of the straps was not magnetic, the other one was VERY magnetic! My supplier's response was that the magnet test is not definitive in ascertaining stainless steel.... that didn't explain why they were different to each other tho!
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Also, I'm not sure your location of the bolt is correct... I normally have them at the rear, pointing up perpendicular to the ground.
911SC '82
I saw on ebay that someone sells a kit short + long for 3.2 models.
bottom line I'm baffled (muffled?) that Danks doesn't include the right straps! btw, did anyone have problems with the braket/hanger? anything I should be aware? |
911SC '82
is this an AI-generated answer because it seems you didn't understand at all what are we talking about... |
911SC '82
problem solved with longer bolts 100mm. stainless steel.
Pelican Parts Vendor
We'll have engineering check the lengths of 901 111 157 04 (1965-1975, 1976-1977 S, 1978-1983), 930 111 159 00 (1984-1985, 1986-1989 Carrera, 1989 Speedster), and 930 111 155 01 (1986-1989 Turbo Carrera), and report back.
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2 Last edited by UROParts; 06-06-2024 at 02:43 PM.. |
