82 SC Fluctuating Lambda Duty Cycle
I've got another one for the brain trust. If anyone has seen my recent posts, I recently rebuild the CIS on my 82 SC and performed a major service. Now I'm trying to set the mixture via the test port on the lambda system. With an oscilloscope attached to the test port (red wire to ground, black to the green wire on the test port), I'm getting the following fluctuating duty cycle. Is this normal?
https://youtu.be/cDs5I0ifs8U The duty cycle is pinging back and forth between 45% and 60% and minor adjustments to the mixture screw only shift this up or down without changing the fluctuating (at least I think). Engine is warmed up. Things to note: - I verified no air leaks by smoke testing the system after CIS rebuild (replaced all vacuum lines, injector seals/buckets, new airbox); when I pop off the oil fill cap the throttle changes significantly, indicating there is no significant air leak - valve lash is set, head studs are tight - ignition timing was set, 5 deg BTDC at idle, advances with more throttle - WUR is rebuilt, system/control pressures at spec - just replaced 02 sensor, old sensor was original (!!) and was giving the same duty cycle fluctuations Do I just need to fiddle with the mixture adjustment more and it will even out? It seems like the system is fighting to try to get to lambda 1. |
I have an 83 with functioning lambda. It fluctuates, after warmup, usually abut 8, meaning + or- 4%
around whatever I am shooting for. I have seen it fluctuate more like yours does but I just assume the O2 sensor has dropped below the temp it needs to work. Try raising your idle to maybe 1200 the reset and see if it holds a tighter range. |
I have not used a scope for the lambda adjustment. I have used a dwell meter and adjusted for a minimum swing on the meter from left to right on a 4 cylinder scale.
You can clearly hear the uneasy and very oscillating idle. Check the voltage at the OXS Relay under the passenger seat if at least 12v are present, made its too. As you have an oscilloscope also check the signal at the frequency valve port 15. Here a clear peak and hold pWM signal which drives the frequency valve should be present. |
This is how it should look like at port 15 of the ECU unit/plug.
Maybe the signal results on your side inverted. http://forums.pelicanparts.com/uploa...1717101989.jpg |
Thanks, guys. I'll check for voltage at relay and look at the signal on port 15 of the ECU, and report back. Hopefully this gives us some idea what is happening.
I use a dwell meter to adjust my car (82 SC). Can't recall how big the swing was last time I did it (years ago) but based on engine sound alone, I'd say your car is completely normal sounding for one that's all warmed up.
Normal. Go drive it!
Interesting feedback. I might be chasing a ghost but I might as well go through the checks. I also bought the car with the O2 system unplugged, which makes me suspect.
A few updates: 1. With the O2 sensor unplugged, the duty cycle is steady at 50%. I thought it was supposed to default to 65% with no O2 sensor... 2. I verified the O2 sensor (which is brand new) is working. The voltage starts around 0.45 and then fluctuates within a few tenths once the frequency valve starts to do its thing. 3. I verified voltage at terminal 30 of the O2 relay, which was 14.4 V at all times. With the car running, terminal 88 was 13.3V. I thought it was strange they were not the same voltage when both are hot. Probably nothing, but let me know what you think. Andrew: what is the best way to get to pin 15 of the ECU while running? I don't see an easy way to backprobe it or disassemble the connector. Any suggestions? |
I have a 1981 SC, Duty cycle varies from 52 to 58 % just checked after a long drive, also the idle doesn't sound like yours, it keeps dead steady, no pulsing whatsoever. Yours seems to surge a little then back, I have no idea what could cause that.
Edit: I see a light surging as yourself when the idle rpm is set high, maybe the advance is bouncing it around too, it's not as rhythmic as yours, more random, but it's there. Only when I drop the rpms to ~ 850 then it's rock steady.. the duty varies somewhere between 52 and 60, so really not that different from yourself, maybe it is somewhat normal which is what other's have said. Phil |
Default is 50% duty cycle when running open loop.
http://forums.pelicanparts.com/uploa...1717293004.jpg Here's a pic from the last experiment I did playing with this.... leads attached to the same ports. I didn't notice any voltage droop but that could simply be the scope. http://forums.pelicanparts.com/uploa...1717270709.jpg |
Andrew, I opened the lambda computer and tapped into port 15. When I initially started the car it was running great and I got the waveform you provided as an example:
http://forums.pelicanparts.com/uploa...1717287017.jpg That must have been before it switched to closed loop because after a few minutes the car started running rougher and the idle started oscillating like I showed above. The waveform also went nuts and the voltage dropped way down to tenths of volts. Here is a video: https://youtu.be/t6j8JmkE7x4 Does this mean the lambda computer could be on faulty, or could something else cause this? |
That wave form looks like the one in the other recent O2 thread where solder was used where it shouldn't have been, rendering the O2 sensor erratic and useless.
Most likely the 2901 quad comparator in the Lambda ECU has gone open-loop (hi-freq oscillations), e.g. cold solder joints. |
I didn't see anything about the age of the current oxygen sensor. The symptoms suggest to me that it might be getting lazy and is on its way out. Replace it and see if the duty cycle fluctuations tighten up to where they should be.
Nix |
O2 sensor is brand new. Had the same symptoms with the old one too.
It sounds like the lambda computer may be the culprit. Any suggestions for repair? I see the specialized ECU folks fix these and the feedback on the forum is mostly positive. Alternatively, anyone have a known good one they want to sell? |
OP, Open it up and have a look see. It's all analog components in there anyway. Might be something obvious. |
The other guys have covered most of the bases. However, don't overlook the frequency valve itself. It may be dirty or sticking. I would put a bottle of Chevron Techron Concentrate in the tank, go drive the snot out of it for a week or so, then see if the idle stabilizes. If not, then remove and inspect the FV. Since it works like a fuel injector, you can have it cleaned by a shop that cleans fuel injectors.
My experience with old electronic components (as well as new ones) is that they tend to either work, or not. Sometimes they are intermittent (the worst kind). Check and clean electrical connections too. |
And if maybe finally after checking the ECU it shows that a bigger repair is not worth it, have a look here. https://nineelevenheaven.wordpress.com/the-911-sc-3-0-engine-with-catalyst-and-lambda-control/ https://nineelevenheaven.wordpress.com/the-lambda-control-of-the-911-sc/ https://nineelevenheaven.wordpress.com/optimized-control-unit-ecu-for-the-911-sc-with-lambda-control/ |
Thanks for the help, everyone. Andrew, your website is great.
Here is a photo of the lambda computer. Nothing sticks out to me. http://forums.pelicanparts.com/uploa...1717418941.jpg I'll check out the website above, but first I'm going to double-check the relay is functioning properly. I verified it is getting 12V at terminals 88 and 30 while running, but it occurs to me that I didn't check whether the switched power at terminal 87 or 87B remains hot. I'll report back tonight. |
The typical circuit board problems occur on the bottom, where the circuit tracks are, and intermittencies occur.
The worst case problem occurs when the hybrid circuit fails, as there's no replacement. http://forums.pelicanparts.com/uploa...1717421840.jpg |
I hate those hybrid circuits and it seems they are almost everywhere in our cars. The heater blower relay and the newest version of heater automatic control are partly built with such hybrid cards and that makes them very hard to hack.
Good to know.
Confirmed that the relay is working perfectly fine. I will send out the ECU for testing/repair. |
Closing out this thread, I sent out the lambda computer to Loren at systemsc and it turned out to be in good working order. The signal to the frequency valve was as expected and there were no other issues. Loren resoldered some connections anyway and took the time to discuss the issues I thought I was having. I highly recommend Loren's services. After some discussion, I updated my scope settings and fine-tuned the mixture screw to get the following at the test port:
https://www.youtube.com/watch?v=nZf-Si8OtXY Loren confirmed some idle fluctuation is normal, and it looks like the duty cycle fluctuations are not as extreme. From here, Loren suggested I also confirm the following, which I will do soon: 1. monitor the cold start enrichment duty cycle (~ 70%), a ground (ECU pin 7) from the temp switch on the chain cover right bank 2. check the acceleration enrichment switch ECU pins 12 & 14, from the relay next to the ECU, as the acceleration pedal reaches about 1/2 way full throttle Otherwise, she's up and running! |
In hindsight, the duty cycle oscillation between 60 and 45 should have informed us right off the bat. |
Do you have a financial interest in this company? |
They support early 911s thru 906s, 959s, 993s, to the Porsche Cayenne. Surprised you haven't heard about them. Give them a call sometime. |
| All times are GMT -8. The time now is 07:46 PM. |
