I'm using R12.
I don't have a high pressure gauge.
I will get a fan on the rear condensor. But why are my vent temps still high? :( Thanks... |
Don't have my tables with me but in general terms high side pressures over 250 psi will hamper cooling and 325 psi or greater indicates the system is overheating (lack of cooling in the condenser). Jim
Typical high side pressures (without adjustment for altitude):
For R-12 80 F ambient 170 to 210 psi 85 F ambient 180 to 220 psi 90 F ambient 190 to 230 psi 95 F ambient 205 to 250 psi 100 F ambient 220 to 270 psi For R-134a 70 to 80 F ambient 115 to 200 psi 80 to 90 F ambient 140 to 235 psi 90 to 100 F ambient 165 to 270 psi 100 to 110 F ambient 210 to 310 psi |
Jim: GREAT information! Do you have a similar table for low side pressures, or do they remain somewhat constant regardless of ambient temperature and/or altitude?
Thanks much! |
For R-12 32 F Evaporator temp 30 psi 36 F Evaporator temp 35 psi 42 F Evaporator temp 40 psi 48 F Evaporator temp 45 psi 53 F Evaporator temp 50 psi For 134a 33-50 F Evaporator temp 16 to 29 psi 33-60 F Evaporator temp 19 to 39 psi 40-65 F Evaporator temp 25 to 43 psi 48-65 F Evaporator temp 37 to 51 psi |
| All times are GMT -8. The time now is 06:35 PM. |
