Anyways, I ordered longer bolts. it seems the common solution. |
are you referring to this kind of problem? https://forums.pelicanparts.com/porsche-911-technical-forum/911576-help-installing-dansk-sport-muffler.html for the straps, a longer bolt will suffice. but now I'm curious about the bracket/hanger, why did you mention that? |
https://i.imgur.com/j3vAHTil.jpg If you use the 3.0 hanger and longer straps, you still need another 6-8 inches of strap in order for it to sit proper: https://i.imgur.com/ICA8gzSl.jpg However, if you use the 3.2 hanger, which positions the strap supports lower, everything bolts up proper-like. This muffler was ordered from Pelican Parts, and is said to fit my 3.0 SC. Manufacturer says the same thing. When actually attached, though? Not even close. Basically, if you match your muffler, hanger, and straps, it'll all work out. (Also worth noting is that this is for a 1-in 1-out muffler. YMMV with the dual-input mufflers, such as used with SSIs.) Quote:
Muffler: Aluminized Steel with Grey Finish & 70 mm Stainless Tail Pipe - 101010157 - JP Group Dansk 1620606300 Test Pipe: Test Pipe for Catalytic Converter Position - Polished Stainless Steel - 991012256 - JP Group Dansk 1620200600 3.0 Straps: Porsche Clamp 901-111-157-04-OEM x2 (WRONG ONE) 3.0 Hanger: Porsche Muffler Support Bracket 901-111-151-04-OEM (WRONG ONE) 3.2 Straps: Dansk Porsche Exhaust Muffler Strap Kit 1621700210-INT 3.2 Hanger: Porsche Muffler Support Bracket 930-111-151-01-OEM |
fantastic thanks to confirm, you have a 911 SC correct? year? thanks for the links, it will save me lot of headaches |
are you sure your test pipe is what causing all this? I still have the cat, and it seems pretty high, close to the engine than your pipe... I'll take some measurements later, just in case |
Interesting, Just installed a test pipe along with the new muffler and have the same issue with the right side a little higher. I did not use the long strap that goes around the hot air tube, just used the bracket. It did appear the test pipe was causing the issue.
I do know for sure the PET book recommended straps are too short and so I got 100mm bolts... but it feels too strange that you also need a new bracket |
Also, @FlatOutFly - Are you using the 3.0 hanger and straps, or the 3.2? |
I wonder if any of you guys took pictures of the old muffler compared to the new one.
Also the old catalytic pre-muffler vs the test pipe They all look the same but i guess a degree or two can cause big difference as you guys reported Im attempting to do the job Saturday… will see if it fits |
| All times are GMT -8. The time now is 01:24 AM. |
