Slippery Slope Expert
Steam Driver's Avatar
Start-up/Break-In Oil
I hate to open this can of worms but what’s the current thinking on this?
Braced for the avalanche . . .!
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.”
Old 01-07-2024, 06:01 AM
Search.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 01-07-2024, 06:35 AM
https://lnengineering.com/oil.html
I found this helpful
Old 01-07-2024, 07:25 AM
Most rebuilders use it. I use it. I don’t keep it in a long time
I know two really good rebuilders who’ve built everything from vw’s to 935’s….started out at vasek polak. They don’t use break in oil, just non synthetic Porsche oil.
it's not leaking....it's just marking it's territory
Old 01-07-2024, 09:27 AM
Schulisco's Avatar
Video about the actual 30th anniversary model of the RUF CTR Yellowbird:
https://youtu.be/gN_U7VRqbxw?si=T8EAOjZFLo2GAP_-
At 35:00 and following there are some details about the breakin run they do:
- 10W60 ("break in") oil (no brand or exact type named)
- engine is completely new constructed by RUF and no Porsche engine anymore, watercooled, biturbo, dry sump, at least 710 bhp, mostly more. This particular engine produces 727bhp@6900rpm and 913Nm of torque at 4000rpm.
- breakin procedure take 90mins warmup at different speeds and load, followed by 2hrs of terror increased up to full load & power, the technicians say that the engine must stand this, otherwise it's not good to go to the customers. Customers get therefore an alreafy breaked in and bullet proof engine..
- oil is used for approx. 8 engines before being
replaced, when engine gets installed in the car it gets fresh oil and new oil filter
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 01-07-2024, 10:05 AM
Northern Motorhead
wildcat077's Avatar
When i build a 2.5 race engine for my SP2 car i always use Amsoil break in oil for the first break in run ... it's not overly expensive and i imagine it does serve a purpose.
I'm sure there's other brands out there but i also use Amsoil 15w50 Dominator oil in my 911 and the 944 with a prefered customer discount.
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 01-07-2024, 10:40 AM
proporsche's Avatar
would you explain this? ,just wondering..oil is used for approx. 8 engines before being.....
so they reuse the oil after break ins on 8 engines???
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 01-07-2024, 11:18 AM
Schulisco's Avatar
As they said in the video - yes.
I also heard somewhere else that other engine builders also use these oils for some engines. Unfortunately I
cannot name the people...too long ago.
If the oil is from good quality and fresh, and I suppose they filter it before using on the next engine, I don't see
any issues... I remember that these oils, if we're talking about specialized breakin oils, might have different ingredients than common engine oils for normal street use... IIRC they're mostly simple single grade mineral oils with higher ZDDP/zinc, esp. for camshafts.
Thomas
Old 01-07-2024, 12:33 PM
Northern Motorhead
wildcat077's Avatar
I can't imagine a serious engine builder using the same oil on eight different engines for break in ?
My engines are broken in on a dyno and i bring my own oil and filters and there is no way i would even consider using the break in oil in anything after 30 minutes , not even on my lawn tractor ...
I mean the Amsoil break in oil is something like $11.00 dollars a liter, what's that compared to a 10K engine rebuild ?
Cheers
Phil
Old 01-07-2024, 02:03 PM
Schulisco's Avatar
Everyone can do what they think is right.
I personally think it's exaggerated to use a new oil on every new engine to breakin. On the other hand two cans of oil is by far cheaper than a rebuild of course. But I also doubt that you prevent a rebuild with new oil. If a rebuild after breakin is necessary then there are far more serious problems you cannot cover with fresh oil...
And I also don't see an issue on using the same oil on several engines:
- no real cold start on icy temperatures less than 0°C / 32°F, just a single "cold" start on workshop ambient temperature higher than 15°C/59°F
- no harsh operation conditions with stop'n'go, hot or cold wheather
- no longer cold running times over years or too rich fuel mixture with excessive fuel dilution
- almost no oil pollution from combustion residues due to low running times, e.g. 8x3,5hrs=28hrs avg running time...this is not much...(1,5 breakin + 2 hrs full load)
Thomas
Old 01-07-2024, 02:40 PM
Schulisco's Avatar
https://www.enginebuildermag.com/2019/08/break-in-oils/
Break-In Oils
A proper break-in oil is formulated from the ground up to be a break-in oil. Many of the surface-active chemistries that would be in a regular race oil are reduced or removed in a break-in oil.
Aug 14, 2019
Today’s engines have good oil flowing to almost every engine component except one – the camshaft. The oil’s ability to reach the top of the engine may be limited at best. Using a windage tray, or modifying connecting rod side clearances for less oil splash, reduces the amount of oil that reaches the camshaft.
Custom oil pans further complicate both the break-in process and camshaft lubrication in general. While windage reduction frees up horsepower, proper supply of oil to the camshaft and lifters will keep the engine from coming back in pieces. You may painstakingly select the components for your engine build, but how much attention are you giving to the oil you use for the break-in process?
Break-in oils have existed long before the flat-tappet cam break-in fiasco of the mid-2000s. There is even a chapter dedicated to break-in oils in the “SAE Lubricants Handbook.” It was commonplace for OEMs to use break-in oils before car leasing became popular. As the EPA fuel economy requirements tightened, the need for less maintenance and better fuel economy ended the use of break-in oils as factory fill in new vehicles.
However, the reduction of ZDDP (Zinc) and increase in detergent additives as part of the API SM oil specification in 2005, brought break-in oil back into play. In 2005, Joe Gibbs Driven (now known as Driven Racing Oil), introduced a break-in oil specifically designed to address the flat tappet cam break-in issues associated with the new specification of oils. During this time, Joe Gibbs Racing’s engine shop began experimenting with a custom blended oil because they were having flat tappet break-in problems of their own with the oil they were using. A solution was found, and then the team noticed others in the same boat. The Driven brand was born and was the first high zinc, low detergent, petroleum break-in oil offered to the engine builder market.
Break-in oil uses chemistry to smooth the load-bearing parts in the engine. Smoother surfaces can carry more load, exhibit less material fatigue and reduce friction.
A proper break-in oil is formulated from the ground up to be a break-in oil. According to Maxima Racing Oils’ Mike Marcella, many of the surface-active chemistries that would be in a regular race oil are reduced or removed in a break-in oil. “This prevents unnecessary competition between the chemistries you want on the surface (anti-wear chemistries), and the chemistries you don’t want (friction modifiers, detergents, dispersants).”
However, blindly throwing large amounts of anti-wear chemistry at it doesn’t achieve the most effective break-in either. “A certain amount of wear must be allowed for proper break-in to occur,” says Marcella. “So, if huge amounts of ZDDP are used in a break-in oil, too large of an anti-wear film can be formed, actually preventing removal of surface asperities and delaying break-in. Further, the unnecessarily large films of excessive ZDDP can hinder power, creating a situation that is not ideal for a high-performance engine.”
Marcella claims that Maxima’s break-in oils achieve faster ring seating and increased power output by balancing the chemistry. “By using the proper anti-wear chemistries in the correct amount and balancing them with the rest of the formulation, we can achieve more power and a quicker ring sealing.”
The Driven brand was the first high zinc, low detergent, petroleum break-in oil offered to the engine builder market.
Driven Racing Oil’s Lake Speed Jr., says that break-in oils and race oils differ dramatically in terms of chemistry, and that is because they have very different jobs. “While the race oil is designed to reduce wear and increase horsepower, the job of the break-in oil is to allow a controlled amount of wear. As such, race oils are loaded with friction modifiers and other components that reduce friction. On the other hand, break-in oils don’t contain friction reducers. Piston rings are especially sensitive to low friction oils during break-in. For these reasons, break-in oils are typically petroleum-based (non-synthetic) and don’t contain friction modifiers.
Because break-in oils are also designed to protect camshafts and valvetrain parts during break-in, they typically contain higher levels of ZDDP. The extra ZDDP in break-in oils prevents scuffing of flat-tappet cams and galling of pushrod tips during initial break-in. A properly formulated break-in oil doesn’t require an additional ZDDP or other additives for break-in. In fact, too much ZDDP can actually increase camshaft and valvetrain wear. Everything on chemistry is a balancing act, so be careful not to fall into the “if a little is good, more must be better” trap.
Technically speaking, break-in oils contain higher levels (typically double) of secondary ZDDP, which is the most active type of ZDDP (there are multiple types of ZDDP). Also, break-in oils are generally low detergent (like the old days of straight 30, non-detergent for break-in). The lower detergent level allows the secondary ZDDP to be more effective. Lake Speed says that compared to off-the-shelf diesel oils (high detergent), break-in oils, like Driven’s BR40, reduce break-in wear by more than 30% and improve ring seal.
Various chemistries within a regular race oil will slow down or completely prevent the break-in process. Marcella says, “Most race-specific oils have ZDDP levels that are too high to allow the removal of surface asperities required for proper break-in and also contain higher levels of other surface-active chemistries that will also prevent removal of said asperities.”
Proper supply of oil to the camshaft and lifters will keep the engine from coming back in pieces.
Break-in oil uses chemistry to smooth the load-bearing parts in the engine. Smoother surfaces can carry more load, exhibit less material fatigue and reduce friction, according to Speed. “By reducing valvetrain wear during initial break-in, overall engine wear is reduced. Because oil filters never remove 100% of the contaminants in the oil, the wear debris from the valvetrain (especially from flat tappet cams) causes abrasive wear in other parts of the engine. Used oil analysis has proven that lower iron wear metals (typically valvetrain) during break-in reduces aluminum, copper, tin and lead (from pistons, bushings and bearings). The bottom line is that all engines benefit from break-in oil, not just flat tappet camshaft engines.”
How long should you leave a break-in oil in before draining for proper race oil? According to Speed, they recommend a 20-minute initial break-in at 2,800 rpm with 10% applied load on a race engine. After that, change the oil filter and top off the oil level. With the engine warmed up, begin making sweep tests and gradually bringing up the peak rpm of the sweep until the engine has run to full rpm several times. Once the power level plateaus from test to test, stop the engine and drain the break-in oil. The engine is now ready for the race oil.
Marcella says Maxima doesn’t tell professional engine builders how to break-in their engines. It’s is a preference for each engine builder how to go about the process. “It is really up to the user and what they’re comfortable with based on their experience. Truly, once the compression targets are met and the engine builder deems the engine appropriately broken in, the oil can be changed for a regular race oil. Having said that, many users of Maxima break-in oil will continue using the oil as a regular oil. While we don’t recommend this and prefer users switch to a regular race oil, if the user is getting good performance, it’d be hard to argue with those results.”
One of the most critical functions of motor oil is to remove heat from a sliding metal-on-metal surface. The oil cools as it flows through the bearing and removes the heat caused by friction similar to air flowing around a cylinder head. But in a break-in oil, you need to allow some friction and wear to happen for the camshaft and rings to seat properly. ....
Old 01-07-2024, 03:36 PM
Well, Here's what my engine builder and I have done following our recent complete rebuild (The 'Prodified' 3.2SS in the Engine Rebuilding Forum): Driven BR (15W50) initial for first start and cam run-in. Drain and Refill Oil with new Driven BR & New Filter. Initial Drive for 30 minutes to start seating rings with acceleration/deceleration. Drain and Refill Oil with SWEPCO 20W50 engine running oil and new filter.
I only have 200 miles in 2 drives on the SWEPCO running oil, and I plan to change it and filter again at 500 miles with new SWEPCO. My mechanic is not sure this is necessary, FWIW. He normally lets it run-in to 1000 miles, when he does his valve adjustment, oil and filter change.
Let us know what you do, and good luck.
Last edited by 911MANN; 01-08-2024 at 04:22 AM.. Reason: My previous reply was incomplete.
Old 01-07-2024, 04:33 PM
Thomas
Is there a consideration of the microscopic particles generated when an engine is fired the first time. I would never imagine using "break in oil" ever again, maybe in my lawnmower
Old 06-13-2024, 12:39 PM
proporsche's Avatar
Break-In Oils
Aug 14, 2019
oh dear;-))))))
Old 06-13-2024, 01:01 PM
