walt's Avatar
Mysterious Fuel Leak
I had my 3.6 conversion up quite high on rear jack stands for a few days looking for a rattle. I set the car back down and backed out of the garage leaving a trail of fuel behind me. In half a minute probably 1/2 cup of gas dripping near the right rear sway bar mount. Pulled it back in the garage and a few hours later tried to find the problem but nothing and no longer leaking. Anyone experience this? I've had the rear raised many times in the past, but this is a first.
Walt
82SC 3.0
81SC 3.6
Old 06-01-2024, 07:10 PM
PCA Member since 1988
What induction and fuel system are you using?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-01-2024, 11:11 PM
walt's Avatar
This is a stock system from a 91. Years ago I had a bad fuel pressure regulator that leaked into the resonance chamber and finally out on the engine block. The symptoms are very different here.
One other thing, I never top off the fuel tank to the very top except this one time but, don't see why that would matter.
Walt
82SC 3.0
81SC 3.6
Old 06-02-2024, 05:15 AM
Yeah, I don't see why jacking up the tail end would cause gas leaks at the rear. You will have to run the pump or start the engine and see where it's coming from.
Old 06-02-2024, 01:23 PM
walt's Avatar
No leaks found so threw a fire extinguisher in the car and continued to drive it. Then, after 3 weeks I start the car and the revs go sky high and settles back down after no more than a second. Pull out of the garage and have my second major fuel spill. Open the decklid and see fuel dripping from the air filter. Thinking the only way fuel could get into the intake is thru a faulty fuel pressure regulator, I pulled a vacuum on the FRP diaphragm and it checked good.
It's always been a bit hard to start if it sits more than 3-4 days but other than that it runs great.
Walt
82SC 3.0
81SC 3.6
Old 06-25-2024, 03:54 PM
BoxsterGT's Avatar
Porsche Crest
The 964 Air Box & Filter are on the right side, above where the Fuel Feed connects to the Fuel Rail......
I would pull off the Air Filter Cover and carefully inspect the Feed Hose and the Main Tee.....
Since this is an engine transplant I suspect there is an issue with the hoses and fuel is collecting in the Air Box.
Are they factory original?
Len
Old 06-25-2024, 05:02 PM
walt's Avatar
Len, I just finished removing the intake manifold to get a better look at everything. Unfortunately, I am not finding anything unusual with all the hoses and connections in good condition and tight.
What I can't explain is why this is an intermittent leak and when it does leak it's like spewing out of a garden hose (literally) and hitting the firewall. After the last leak I had someone sit in the car and start it a dozen times with me watching and not a drop.
Also, I don't have an airbox but an aFe flow pro filter. The main supply hose coming from the fuel filter is stainless steel braided. Thanks for any suggestions going forward.
Walt
82SC 3.0
81SC 3.6
Old 06-30-2024, 07:46 AM
walt's Avatar
Think I found it. Looks like the rubber from the co-line hose is extruding out the front end of the ferrule on the one side.
Walt
82SC 3.0
81SC 3.6
Old 06-30-2024, 11:56 AM
BoxsterGT's Avatar
Porsche Crest
WooHoo!
Discovered BEFORE a disaster!
Len
Old 06-30-2024, 02:56 PM
Still here
pmax's Avatar
Seems unusual for a line to bust out of the ferrule.
Should that be aligned ?
Not familiar with the 964, why is that bracket shaped like that with a "hole" ?
Old 06-30-2024, 05:16 PM
BoxsterGT's Avatar
Porsche Crest
walt-
This is not rubber hose. It is Polyamide tube and cannot be repaired with hose clamps.
Once you remove the Tee assembly, post a clear photo so we can evaluate this.
I have made up a fixture for these 964 Main Tee assemblies.....
and would be happy to help.
Please email me for info.....len.cummings @ verizon.net but without the spaces.
Len
Old 07-01-2024, 08:36 AM
