-   -   Minimum safe thread length for wheel studs when adding spacers? (http://forums.pelicanparts.com/porsche-911-technical-forum/1162470-minimum-safe-thread-length-wheel-studs-when-adding-spacers.html)
francesconyc 06-02-2024 05:18 PM
What is the minimum safe thread length for wheel studs when adding spacers?
I'm asking because the other day I changed the rear rotors and I wanted to add some H&R 14mm spacers I recently bought. These spacers come with 70mm long stud. 70mm is way too long to be able to fit them without removing the entire hub. maybe, I say maybe but I need confirmation, I could remove the parking brake gears to have lateral access but 70mm may be still too long
Anyway, in the meantime, I measured the 70mm studs inserted in the old rotors with the 14mm spacer. I also fully screwed the lug nut entirely (~27mm), which leaves me 18mm to be filled by the wheel itself + the hub disc
Does anyone know those values by any chance (wheel + hub disc)?
how to calculate a safe stud length with Fuchs wheels?
IF the current wheel bolt/studs are 45mm, adding a 14mm spacer, wouldn't require only a 50-58mm stud? those 10mm can help avoid removing the hub I think
btw my rear wheels are original Fuchs 7Jx16
PeteKz 06-02-2024 11:12 PM
General engineering rule of thumb is that the nut should thread onto the bolt/stud at least the diameter of the stud or bolt. E.g., if the bolt is 8mm in diameter, then the nut should engage at least 8mm of threads.
panama911 06-03-2024 12:52 AM
Or get an open steel lug nut - if this gets fully threaded on (stud fills nut completely), you're OK...
francesconyc 06-03-2024 07:21 AM
I can try with an open nut good point.
The closed classic 911 are very long, I measured 26mm of thread, but I counted 6 turns to reach 14mm of thread.
i know is a bit of a strange topic, but I'm really trying to see if I can install some longer studs without pain. otherwise I will return them
