mordecaibrown's Avatar
Warm Up Regulator
1977 911S
Had the car in storage where I paid to have car started at least once a month who knows if they did. Now when it's back home when starting its seams to be starving for gas going in and out for a minute. Then idols fine. Is that from sitting too much? Or the Warm Up regulator needs maintenance? Or just run it awhile or maybe some seafoam? It was fine before storage.
Thanks,
Sam
Old 04-04-2024, 06:27 PM
My opinion: Get a fresh tank of gas and drive the thing for a week. Then do a full pressure test and post the results.
Old 04-04-2024, 09:11 PM
PCA Member since 1988
How long was it stored? Probably just ethanol contaminated gas gone bad.
Same advice as fanaudical: Either drain or run the tank nearly dry, then refill with fresh gas and a cleaner. I prefer "Chevron Techron Concentrate." Others liike Seafoam, BG44, etc. Drive it hard for about a week. See if it clears up.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-04-2024, 10:08 PM
stored about 6 months but there was some old gas in there before that. maybe about 1/4 tank. I did put some sta bil in there before I stored the car.
Old 04-05-2024, 05:47 AM
Quarter tank (5 gal) is too low for storage plus the tank level sender and gauge are not that accurate. If you’re still driving around on a quarter tank, did the low fuel indicator light pop on?
Making stops and turns on a very low tank can cause the symptoms you describe as it struggles to pull up fuel.
Yes - get a full tank of gas (premium, it has more detergents) and add some fuel additive too.
Possibility that just sitting too long can produce some weird start up issues and these go away with more driving as I have found like surging or hunting for idle, sputter here or there.
Also, Stabil has to be somewhat diluted accordingly to the ratios of gas it treats. Some other brands will treat an entire 20 gal tank and recommend adding with fill up to avoid issues. Improper dilution rate of Stabil i noticed (lawnmowers etc ) tends to get sticky and burns differently after winter storage.
Old 04-05-2024, 08:02 AM
Use non ethanol fuel. I have a tank at home but last I checked, here, it was about 6 bucks a gallon. Most marinas have it too but you have to pack jugs.
Old 04-05-2024, 08:54 AM
Ok thanks I will run through the gas. once is warms up it runs fine and idols fine just starting it But again I have only started it a few times since I got it back from storage.
Old 04-05-2024, 07:58 PM
Also I took it for ride yesterday and put a bit of Sea Foam in will that help? ran perfect except for the starting but again I have only started a few times since I took it out of storage
Old 04-06-2024, 08:34 AM
It might help. Run out the old gas, then refill with new gas and add your favorite fuel system cleaner to the tank. Drive the snot out of it. Rinse and repeat. Then tell us how it's running.
Old 04-06-2024, 09:48 PM
E Sully's Avatar
When the tank is near empty, remove the strainer from the gas tank and clean or replace it. When was the last time it had a tune up, points distributor cap, plugs, etc?
Ed
1973.5 T
Old 04-07-2024, 04:59 AM
HarryD's Avatar
FWIW, Bills Service in Lake Oswego has it at their drive-up pump. Near PIR, there is Demara Service on 9125 Ne M L King Blvd.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 06-07-2024, 04:45 PM
You might want to also check the points/distributor. When I store my '77 911S sometimes I have issues with the points/distributor metal pieces getting oxidation which creates spark issues. I just use a bit a sandpaper to clear up the oxidation and it runs fine afterward.
Old 06-07-2024, 09:23 PM
