Bang, then she stopped…
Hi All,
I have ‘88 911 and I’m not technically savvy…
I’ve just spent a bunch getting the car back on the road after a long layoff…-!: as soon as I got it back from interstate the clutch dropped to the floor and I couldn’t change gears. After a bit of research, I decided to change the clutch slave cylinder - which I did this morning.
Feeling relatively proud of myself, (again, not technically savvy) I took it for a drive.
Feeling confident, I was driving aggressively (still below redline) when the engine lost power, and the engine started hunting between idle and 2500 rpm.
I coasted down the hill and when I got to a stop the engine cut out. The engine turns over but doesn’t fire. The first time I tried it blew a bit of smoke, but subdsequently doesn’t.
When I look in the engine bay, the only thing that I can see is a belt missing, but my limited research indicates it is a belt leading to the ‘air pump’ which isn’t actullay needed? (Smallish pump to the right of the main fan (in Australia)). So my initial hope of just changing a belt is unlikely the outcome.
Any help please on what to check?
Pete
Old 06-01-2024, 09:59 PM
Belt issue aside I wonder if your brake booster gave it up and now it’s a vacuum leak.
Old 06-01-2024, 11:05 PM
PCA Member since 1988
Start with the basics; Compression, fuel, spark.
Squirt starting spray into the intake and see if it fires. If yes, then you have spark, but are lacking fuel, or have a large intake air leak. If not, then you are probably lacking spark. Troubleshoot the appropriate branch of the tree.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-01-2024, 11:43 PM
Check/change your dme relay under seat I think?
Old 06-02-2024, 12:00 AM
Thanks-I’ve just had that changed out as part of some significant work, so hope it’s not that!
Old 06-02-2024, 12:20 AM
Is this common? Would it explain the ‘surging’ as it happened (I really don’t know much about the mechanics of it all!)
Old 06-02-2024, 12:25 AM
Also….
If what I am thinking is correct, and it is the Air Pump to the right of the main fan, what is the thing on the front of the pump? It appears as though the belt would feed into a groove on the pump, but then there is another plate on the very front which seems to be able to move completely independent of the pump (ie it is loose). Is this the air pump pulley ? If so, it doesn’t seem to have any connections to anything???
Old 06-02-2024, 01:36 AM
What you describe seems to be the A/C compressor. The plate that is free to move is the compressor clutch.
Gilles
RoW 88 Carrera coupé
Old 06-02-2024, 05:35 AM
Do you have a pop off valve? Sometimes the seal comes off.
Or check your air box for cracks.
Ahh disregard.. I thought it's an SC.
Seems like a vacuum leak somewhere.
Old 06-02-2024, 08:19 AM
Still here
pmax's Avatar
Do the simple stuff first, check the fuses.
See below thread, there's a pic of the fuse panel in one of the posts.
3.2 just died after a ride.
Old 06-02-2024, 12:24 PM
So…
No fuses blown. Had a look under the hood again, and can’t find any obvious breaks/pipes missing. Did find the below cables not connected to anything though. Any thoughts?
Also, turned it over again and the car ‘tried’ to start, but didn’t. Subsequent attempts just had it run over without a fire…
Old 06-02-2024, 11:36 PM
Test with starting spray.
Old 06-03-2024, 12:24 AM
Old 06-03-2024, 01:11 AM
Old 06-03-2024, 01:12 AM
Read here for 911 3.2 no-start help; 911 3.2 No-Start Troubleshooting
And here under Porsche, DME ECM; https://www.systemsc.com/problems.htm
Dave
Old 06-03-2024, 08:01 AM
Update:
After a couple of days without joy, a friend came over to have a bit of a look and couldn’t see any obvious signs. Took the leads off the plugs and apparently that looked good.
When finished I tried to start it and after around 15 seconds it tuned over. Running rough and blowing a fair bit of white smoke. I let it run for a minute and then turned it off.
After five minutes, tried again and fired up first go, still pretty rough and still smoking (a little darker).
I had to go out of town, so tried again today. Fired up first time, and still Smokey. Was planning on taking it around the block, but if I touch the accelerator it tries to stall.
Did a bit of googling and it said if a cylinder wasn’t working it could cause richness and roughness, so take if a lead and see if the rpm dropped.
I took off the first two leads without noticing much - but thought they were both a bit loose - compared ro the third which was on tight - and I could feel the current. Anyway, I tried to ensure 1 and 2 were back on tight (which I found quite hard to secure) - but now car won’t even fire again!!!
Thoughts?
Old 06-05-2024, 10:25 PM
I reckon I’ve found the problem. Pretty sure this creates a decent vacuum leak! Just need to find where it goes!
Old 06-06-2024, 12:58 AM
Plug it back to rear of rubber boot.
Gilles
Old 06-06-2024, 01:30 AM
It would be sucking copious amounts of unmetered air and running lean.
I've never heard of those coming out before? Hopefully you got it back in its home.
Where in Aus are you located?
MIke
Brisbane
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 06-06-2024, 01:56 AM
MIke
Brisbane
Hi Mike-I’m in Canberra, but spent a fair bit of time in Brisbane. Just drove the car back from there recently - after it had been in the shop at DHM Auto in Tennyson.
I was on the phone with them today to help trouble shoot. None of this issue was their doing - and they’ve been great. Recommend them if you need any work!
Old 06-06-2024, 02:33 AM
