Green gear oil
I drained my 76 911 gearbox today and found the oil to be green. The car has been on jackstands for at least a decade and the oil is about 20 years old. I remember using Swepco the last time I changed it. I don't remember which Swepco but the most common one that everyone uses so 201.
Its the same color as Simple Green. Has anyone ran into this and do I have a problem? ![]() I'm going to fill the tranny before I stop today and I'll use some GL5 I already have on hand, Valvoline 75w-90. |
Perhaps the copper in some if the components make that happen I wonder?
VooDoo. Use Kendall 80/90 GL-5 instead unless it's a track car.
https://forums.pelicanparts.com/porsche-911-technical-forum/957404-best-oil-915-gearbox.html Bob Kontak says 210 is green so maybe thats what I put in 20 years ago and its still the same color. Its bee so long since I drove this car that I've forgotten what its like. So I'm finally getting it back together but its going slow. I still have a lot of things to service. I don't think the rear wheel bearings have ever been regreased. I did the fronts and they are a piece of cake. |
I have a 76 with 14k miles on it.
It had a reseal for the 915 about 3 years ago. It had Swepco 210 in it at that time. I put Swepco 201 in it recently. Happier with the 201…way fewer issues grinding first. Last edited by Balisong; 06-04-2024 at 08:15 PM.. |
Rear wheel bearings are sealed units. Sure, you can pop the seal and inject some grease with a needle, but I'm not sure I've ever heard of that as standard maintenance...
Swepco 201 is green, OP. Nothing to be concerned about. I used the same fluid in my box.
Still here
After 20 yrs, does it stink still ?
My 201 is Smurf blue.
Fleabit peanut monkey
I think what I typed in the linked 2017 thread was incorrect.
I have the original invoice in a binder from 1996. If it's critical I can find it but I am very certain they stuff I ran was red from 96 - 2007. My mistake - not 201.
1981 911SC Targa |
Swepco 201 is blue, well the jug I bought is.
1986 Targa Guards Red 2021 MT09 SP |
Maybe I should put Royal Purple in and have all the colors covered?
Racer
Avoid 203 and 212 if you have a clutch-based LSD. 210 is red....
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Still here
Blue or green or bluish green, definitely an "unnatural" color for oil, some funky copper based additives perhaps, which might degrade oxidize turning greener over time. I still have an unopened gallon of this stuff sitting in the garage waiting to be put to use. Wonder what the shelf life is. |
Per the SWEPCO Web Site (https://www.swepcolube.com/resources/gear-lubricants/), looking at the SDS sheets:
201 Blue 202 Black Viscous 210 Red 212 Thick Black
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 06-05-2024 at 11:29 PM.. Reason: Correct 201 color. |
And from what I can tell, 201 is blue 202 is blackish green 210 is red (oily red) 212 is thick black thanks guys, I was worried that my synchros have been leached or compromised. I bought the car 21 odd years ago and I did the normal things when buying a used car, change all fluids. I didn't remember the color but I do remember it wasn't the normal amber. I bought a 86 944 from a fellow engineer who worked at K&N and that trans had smurf blue oil. I enjoyed that car immensely and should have held onto it. So I'm convinced the oil is Swepco 202. The oil still looks good. There is no sign of moisture, or that metallic sheen we often see on old oil that has had hard use. It doesn't smell burnt. I could put it back in and not worry about it. The car has been stored in a garage for as long as I've had it, here in Tucson and Riverside County California. Both desert environments. |
Addendum:
Modern gear oils also have different colors. I used to have a gear oil change by a workshop on the 915 of my SC with no success. Their intention was good, but the outcome wasn't: They filled a modern gear gear oil (unknown brand and spec) and the shifting comfort wasn't improved and even worse when warmed up. This modern oil was also green! And so I replaced it by myself afterwards with a old fashioned SAE 90 GL5 mineral oil (Castrol EPX90), with specs pretty similar to the Shell Spirax MB90 which Porsche used for factory fill. Massively improved shifting comfort when warm, way more precise, I found the gears on the first try again, cold are these oils a bit harsh to shift, warm pretty smooth. I cannot emphasize enough to use these oldfashioned oils instead of modern fancy high tech gear box oils. The 915 was designed in the late 50ies/ early 60ies and to be used with oils available at that time. The patended Porsche ring synchronization requires a bit drag torque to make the servo effect work. https://press.porsche.com/prod/presse_pag/PressResources.nsf/Content?ReadForm&languageversionid=60323&archive=10 Quote:
![]() ![]() https://hako-lehrmittel.de/de/produktkatalog/synchronisation-porsche-laengsschnitt/ Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 06-06-2024 at 02:58 AM.. |
1981 911SC Targa |
