911 alignment specs for hoosiers
What are the optimum alignment specs, and tire pressures for a 911 with Hoosier tires? I realize every car and driver is going to be different, just looking for initial specs based on people who have done serious testing on thier setup. I believe Hoosier recomends 2.5 - 3 deg. neg camber. The last time I did testing on the 911 it was on bias ply tires, not at all applicable to radials.
'69 911E 2.7MFI ;996TT;987.2 CaymanS
'71 Volvo P1800E wife's; AMG SLK wife's
'71 Volvo race car
944S; 986S ; 734WHP drift car (son's)
Old 06-24-2003, 02:16 PM
304065's Avatar
I assume you mean Hoosier R3S03 Road Race Radials? I use 225-55R15's on 6s. 40 hot all the way around.
www.hoosiertire.com
As for the specs. . . can't help you there . . . until my smartcamber tool arrives. . .
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-24-2003, 03:01 PM
kwikt 911's Avatar
I use this setup for a-x. -2 degrees Front with slight toe out. -2.5 degrees with slight toe in for the rear. I run 205 50/15 with 35psi fronts and 40psi rears. Seems to work very well. Good luck!
Kevin
72 911T/E
Old 06-24-2003, 05:43 PM
