Optima Battery Life
My friend and I were comparing the life of my recently replaced Optima Batteries. His had a 2006 date code while mine was a youngster with a 2009 code.
We were both amazed.
I had one I replaced last year that was 14 years old. I was both amazed and pleased with how long it lasted.
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel |
The one I just replaced said 2012, I only replaced it for a lighter version, it still worked. I also feel kinda sad I replaced it
81 SC 3.8 Conversion 2017 Macan S INSTAGRAM @tail_spinz |
PCA Member since 1988
Same experience here. The original Optima battery in my Ford GT lasted 16 years. The newer ones are not the same quality.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
I had one in my 356, lasted almost 20 years
Correct on the newer ones not being the same. On my race car that sits in a trailer outside, years ago they would last a decade easily. The last one bought in maybe 2019? lasted 4 years. Now just buy East Penn AGM batteries and get the same or more life cheaper.... Kind of sad.
Steve 91 964 turbo 81 ROW 911SC 11 997.2 |
I've been more impressed with the life from the modern lithium batteries. They don't lose charge while they sit, and they (so far) have lasted just as long as my yellow-top and red-top batteries. Plus they're significantly lighter!
http://forums.pelicanparts.com/porsche-911-technical-forum/1114917-jedi-911sc.html |
