G50 flange and cv bolt spacing
I am wanting to know the bolt hole center line spacing on a G50 output flange and of course the cv joints. I have heard them referred to as 108’s the outside diameter of the cv in mm and 95’s which would be the bolt hole center lines in mm. But I measure the center lines and I get 94mm. I am make a mount and want to be sure. I can’t believe that I am off .040”. That’s a lot
Old 06-19-2024, 01:04 PM
I get around 94/95mm bolt center across from each other. 45mm bolts next to each other. Buy a grease cap and take the guess work out of it.
Old 06-19-2024, 01:53 PM
I measured 94mm
Old 06-19-2024, 06:33 PM
