Why do some 2 pole brake switches have a plastic prong?
Like this.
https://gowesty.com/cdn/shop/products/full_9442e2f914b89536080109952b3b22c7.jpg?v=164729 1843 Just 2 prongs https://socalautoparts.com/wp-content/uploads/2019/06/113945515HGR.jpg
1986 Bosch Icon Wipers coupe. |
If these are both the same Part # in a current PET there’s a letter code for interchangeability.
The last 2 digits would reflect the latest version, changed to meet another change in the socket. The part # can be compared to an older PET…for example: part## 911.111.111.00 being the original rendition and say 911.111.111.03 being the latest. The plastic center spade may be there so it will not insert into an older socket or vice versa. The socket will also have a new two digit suffix on part #. It could also be for import models that may have a multi brand application across other models from Audi to VW. My 2˘. |
'87 Targa
I ran into this very problem. My '87 needs the one without the plastic center excluder. I ordered the correct part number, but received the one with the plastic divider. I simply cut it out, and it works fine.
To your question: Not sure why there are 2 versions. |
the plastic is a actually guide for the original connector
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
But the original connector on many cars does not have that 3rd guide slot
Registered Minimalist
On my original harness on my 75 it's just spade connectors, no plastic guide. My guess is it's just a safety design. On the early cars, the MC is down near the road. If somehow debris hit the wires there and made them touch, it would turn on the brake warning light in the dash. This little plastic guide prevents that from happening.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads Last edited by 75 911s; 06-29-2024 at 08:07 AM.. |
Mine had the plastic, I just cut them off. Easy to do and then they worked just fine.
Which cars years have the plastic 3rd pole slot?
