Installing new tires on my fuchs
Where can i get these valve stems for the fuchs ? Thank-you
http://forums.pelicanparts.com/uploa...1719774105.jpg |
Bolt on Chrome metal valve stems (opposed to rubber), seen them at Jeg’s but most tire shops should be able to stock or source them.
OK , Thank-you !
Or you can just get a set of four Huf RDV021 aluminum valve stems. Same type of valve used on TPMS sensors (minus the sensor) and OEM for Porsche. Much lighter than steel, 1/3 of steel, so less balance weights needed, and the smoother profile and anodized finish keeps cleaner. You can get a set of four under $16 shipped.
https://www.pelicanparts.com/More_Info/36146792829.htm?pn=36-14-6-792-829-M458 http://forums.pelicanparts.com/uploa...1719863014.jpg |
I’ve been using these on all my cars including my Carrera. They are a tad bit taller than the one you listed. I found this tire supply network site that has other models as well as my favorite model below.
SKU TV-CPV High Pressure Chrome Valve Stem (130 psi) http://forums.pelicanparts.com/uploa...1719886853.jpg |
Pretty sure you can get them at most local auto parts stores. We just put some on some BBS wheels
I purchased these on the advice of another pelican thread, installed them on my Fuchs over a year ago and they've worked flawlessly since.
CTopher |
| All times are GMT -8. The time now is 03:51 AM. |
