350HP930's Avatar
Which Cylinder Gets The Hottest . . .
I am hoping someone with some long term experience with the 911 motors, or even better 930s, could tell me which cylinder gets the hottest under WOT.
I am installing a combo CHT/EGT guage and am trying to decide which head I should put the sensor in.
My guess is #2 (center left for those of you unfamiliar with the numbering system) to to the additional radiant heat that cylinder has to deal with.
Old 06-24-2003, 07:23 PM
Information Junky
island911's Avatar
FWIW, I hear #3 (fwd left) is usually the first to cook when something goes awry.
(It is the furthest from the fan.)
Old 06-24-2003, 09:06 PM
I have also heard #3, but then again I heard it here, so if we all heard it from one source and that source was wrong...
But it does make sense.
Old 06-24-2003, 10:37 PM
350HP930's Avatar
Well, #3 would certainly be the easiest to tap for the probe unless someone has a differing opinion.
Old 06-25-2003, 04:07 AM
beepbeep's Avatar
I heard front left is hottest, due to bad cooling...but it's somewhat balanced by the fact that OEM 930 intake is badly designed and flows more into center, so A/F isn't equal for all cylinders...
Thank you for your time,
Old 06-25-2003, 08:15 AM
Cool Re: Which Cylinder Gets The Hottest . . .
Originally posted by 350HP930
[BI am installing a combo CHT/EGT guage and am trying to decide which head I should put the sensor in.
[/B]
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-25-2003, 08:25 AM
beepbeep's Avatar
hehe...that's cool but i think that mounting thermocouples in air-injection holes is even more slick
Old 06-25-2003, 08:45 AM
Cool
maybe.. I don't know enough about it..
I went with the pro act.. they do 1in. from the head for readings.. the SSI alows about 1 1/2in. .............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-25-2003, 09:05 AM
Amac's Avatar
I've heard the guys at Norwoods say #3 and #4 on a 930.
Those two cylinders are the most inline shot through the
intake. Those two cylinders also seem to fail more offen.
That's been the case on two of my race motors.
"Never go faster than you can stop"
85 - 930 (750hp)
Norwood motec 3.5 twin turbo
Old 06-25-2003, 12:34 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
You know, i never thought that teleporting was possible, to instantaneously go from one place to another. But after reading Amac's signature with two 930s , one being 750hp, i think scientists aren't studying the porsches close enough.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 06-25-2003, 01:09 PM
