Lightened Flywheel for 3.2 Carrera...
Hello All,
A friend of mine has a '88 3.2 Carrera. His engine is out for a clutch change ( stock rubber-damped shattered to pieces.. Haha..) Been looking some, but no one seems to be selling a lighted flywheel for these cars. What gives? Patrick Motorsports has a lightened pressure plate which they claim to be much better than a lightened flywheel set-up as they say the 3.2 flywheel can't be lightened much.. What do you guys use? Thanks for any heads-up! ![]() Sprint. |
True -- unless you convert to carbs. Also check out Kennedy & Wevo & SRP.
Navin Johnson
Lookhere they may have something.
It is true you cant take that much weight from a stock disc flywheel though. you can take some though
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Will a lightened flywheel be more prone to chatter? From what I understand this typically comes with the territory and is not a very desirable trait.
Warren & Ron, may you rest in Peace. |
The stock flywheel is pretty light... where you really save on the rotational inertia is with a lightened pressure plate. I have the aluminum RS pressure plate in my car, revs much quicker now.
Your friend should spend his dollars on the pressure plate, leave the flywheel alone.
-- John '00 Boxster S '86 Carrera Coupe (Sold) |
flywheel wts:
Flywheel, stock 3.2L 9.9 flywheel, Patrick Motorsports 6.9 flywheel, Wevo "skeleton" incl ring gear 5.0 |
Call S Car Go Racing, I believe they may have one. 415-485-6026
Jeff 83 SC, Guards Red. |
my Aluminum PP is way lighter than the steel unit (as mentioned above). In Waynes new book CE has a line item on the machine work work for lightening the stock fly wheel. Its pretty reasonable. Any body done this? how much weight does it shave?
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
I have a Truman aluminum flywheel and an aluminum pressure plate in a 3.4-liter carbureted SC. Works absolutely normally. My wife's '03 Boxster is harder to move off a standing start without stalling it.
Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
