Should I use the vacuum pump with the 2 larger hoses disconnected?
Joe Engineer has some written and made videos about it: https://rb.gy/dr2hwv Thomas |
So just tested it. Without vacuum the center port on the backside is closed when blowing into it. When applying Vacuum at around 17 I can blow through both backside ports. So I can consider the Decel valve is good correct?
You can also try squishing the pancake of this precision device, flatten it by 1mm.
That is supposed to help with "unstable idle". |
Porsche Technical Bulletin 81-07 for all 911 https://i.imgur.com/eXA0kWo.png But issue seems to be solved anyhow, even without knocking/pressing the decelleration valve by 1mm ... |
Haven't taken it out for a test drive yet after spraying some silicone spray but I'll try to push it in a bit as per the bulletin. Keep you posted
Thanks |
Thomas |
Should I use a vice on the bracket side to press it?
More good stuff from here ...
https://forums.pelicanparts.com/porsche-911-technical-forum/758788-cis-troubleshooting-dummies.html#post7528901 in fact, it says so explicitly. http://forums.pelicanparts.com/uploa...1724369883.jpg |
| All times are GMT -8. The time now is 11:40 AM. |
