				3.2 sounds like a diesel
			timing chain?
				piston slapping? cylinder not firing? sound out of the exhaust is great. but it backfired that last time I tried to start it. No oil leaks. no smoke at all. change oil with no metal shavings at all. seems like timing is off. but would that make this knocking noise? goes away with revs. Cold start. Sounds normal. But idle is a bit higher when cooler. https://youtube.com/shorts/xoCcPnAEDok?si=KRrkkt-5kqOdrV36 Warm. Knocking sound shows up. Idle lower when warm. https://youtube.com/shorts/m-xKjY6AADo?si=Sk4BD-UZcyNchIK2
			1975 911 3.4 outlaw/hotrod? lsd 1988 535i 1987 535is 1973 bronco ranger Last edited by stubble88; 07-05-2024 at 01:17 PM..  |
			A bit of background detail might be useful.  Has it recently had any work, parts changed etc or did it just start behaving like this one day?
 Car was a dedicated race car Lots of motor work done by AASE in 2018 New clutch (stock) New lightweight flywheel Had straight pipes now has Dansk 2/2 New oil and filter New fuel lines Simple race harness replaced with good used one. DME harness not changed. 911 chips custom. (This ill seek more info on) Headers with Dansk. No cat
	1975 911 3.4 outlaw/hotrod? lsd 1988 535i 1987 535is 1973 bronco ranger  |
			did you know you covered the lens with your finger?;-)
			Sounds like rod bearings.... i`d suggest to drain the engine oil ,look at the drain plugs and what is inside the oil.. Ivan
	1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein.  |
He did - "change oil with no metal shavings at all". I would check timing, check valve adj and rockers. I don't think it's timing chain slap but not too hard to pull the covers to look in there for a collapsed tensioner.
	Gary R.  |
			Is it something as simple as an exhaust gasket having blown.  The reason I say this is it sounds like my SC did when it blew out the air pump pipe next to where the exhaust joins the heads.
 Ivan to the op is it there from cold start or only warm engine?When did it started? also possible wrist pin when the engine is warm-hot..
			1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 06-22-2024 at 09:18 AM..  |
			It’s always there. Hot or cold. I noticed it after adding the muffler. But I’m sure that’s because I can now hear more of the engine. Seems to go away at any rev beyond idle. But there seems to be a vibration. Has solid motor and trans mounts.
			Just a thought, does the engine still use the micro switches on the throttle body ?
	"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla  |
			 It's a 914 ...
			Solid motor mounts can cause vibration. I'd dump those and try again.
	Mechanic's stethoscope can be helpful to localize engine noises. If it's an exhaust leak, probing around under the car with a length of fuel hose with one end near your ear (not too close!) or a recording device can help find it.  |
			 '87 Targa
			I can't quite tell from your clips.
	On my 3.2, I've occasionally encountered somewhat that kind of sound. Mostly at low RPM, idle and a bit above. Really worrying, couldn't pin it down, then it went away. It has come and gone several times over the years. The best I can think is the hydraulic timing chain tensioners are ratcheted. Maybe as they approach the next tooth, the chain is loose enough that it slaps a bit. Then tightens back up as the tensioner advances. I dunno, does this make any sense for you? Or, can anyone chime in on my case?  |
			I did find this on the exit side of MAF. But I’m thinking it’s a result of the backfire and blew it off.
			 Still here
			Adjust the valves first.
			I did spin the flywheel slightly while tightening the bolts. But I did not think it was enough to throw it out of timing.
			 7.0:1 > 11.3:1 > 7.0:1
			Sir, do you know how to use a screwdriver as a stethoscope?  Long shaft screwdriver, place the tip against object like timing chain cover, valve covers etc. then with your thumb over the end of the handle press your ear against your thumb. If it's bottom end related it will probably resonate all over the engine, but if t-chain, top end, hardware in a single cylinder... you should be able to narrow it down.
	Loose fit forged race pistons can rattle like that until load and heat are applied, maybe not quite that loud though.  |
			I did a cold leakdown test
			You can hear air from intake and exhaust. But wouldn’t some air be normal? Cylinder 6 had the most at 14% But for a cold leak down I’m guessing these are really good numbers? At 50psi. I did cylinder 5 at 100psi but it was the exact same % so I didn’t bother on the others. ![]() ![]()
			Have someone push in the clutch while idling to rule out the throw out bearing; they can get noisy like that. But it does sound like a big end bearing to me, based on the video.
 I got a stethoscope. So after a valve adjustment and timing chain examination I’ll have to see how it sounds. Motor was completely rebuilt in 2008 by ASSE. But it was a race car. So who knows. No smoke no oil leaks at all. Records through the years show many oil changes and top end rebuilds.
			Main bearings rumble, big end bearing knock, both noises would not go away when you accelerate the motor, small ends rattle, piston slap also rattle until loaded and expanded with heat, as previous poster explained, your issue sounds more like tappets too tight, and on low rpm the engine is losing too much compression to fire correctly, once above idle, all 6 cylinders kick in, just my ramblings, but as others have said, check valve gap first!!!
					Hope this helps. Ant.
