Ubi bene ibi patria
Hawkeye's-911T's Avatar
Fresh Air Fan - Part # req'd.
Can't find part # for this fresh air blower part -
The broken rubber ring gasket is the part I wish to replace. I've coated it with some glycerin to see if it will aid in the part still being of functional use - it is a bit rough. My luck - it's more than likely NLA as this is a 1970 car. Any help is appreciated - Thanks
Cheers
JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
"As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras
Old 07-02-2024, 01:00 PM
proporsche's Avatar
i just did several works like this..Just reuse it you will be fine,it is not seal just a cushion for vibrations
ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-02-2024, 02:00 PM
Send a message via AIM to fintstone
Since they do not carry them on Pelican...I will give you another source. I just redid my system and got both the Airbox Motor Seal and the flapper valve seals at 914rubber.com
https://914rubber.com/airbox-motor-seal
OEM91157101800S Airbox Motor Seal
OEM91157101800FS Flapper Valve Seals in Blower Housing
One thing I learned in this rebuild is that if you break the plastic in the system (like where the C-clamps go) ...it can be repaired if you don't lose the broken part (with outdoor conduit glue). Even parts under tension.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-02-2024, 04:01 PM
proporsche's Avatar
flintstone..great link ....thanx
Ivan
Old 07-05-2024, 08:34 AM
Ubi bene ibi patria
Hey Thanks "Fint"
Cheers
JB
Old 07-05-2024, 11:26 AM
Looks like PP has the blower motor seal now:
https://www.pelicanparts.com/More_Info/N14R91157101800S.htm?pn=N14R-911-571-018-00S&bc=c&SVSVSI=9282
Old 07-08-2024, 01:15 PM
