-   -   What during an alternator replacement would cause the engine to overheat? (http://forums.pelicanparts.com/porsche-911-technical-forum/1163948-what-during-alternator-replacement-would-cause-engine-overheat.html)
Tommy Z 07-07-2024 08:00 PM
Originally Posted by pmax (Post 12279432)
Either the fan's rotating in "lockstep" with the engine or the belt's squealing.
Something else is the cause of the overheating.
I hear you. I’m just going to have to keep an eye on it. Strange though why it didn’t happen on my test drive post tension adjustment.
Tommy Z 07-08-2024 03:17 PM
Originally Posted by Klax (Post 12279487)
What oil are you running? I've been using VR-1 20-50 for years and I think it runs hotter than the synthetics I used to use.
I'm growing more convinced that the air here in Colorado is just different, meaning far more variable in temp and humidity level than our friends at/near sea level, and that can cause fairly large swings in running temps from day to day and elevation to elevation. A quick weather check says 36% humidity today vs 9% yesterday. When I lived in Ohio, my car never, never, made it to 9:00 on the gauge, but here I'm always above 9:00 and approaching 10:00 in summer unless I'm coasting down the mountain.
Hi Kevin, I'm running Motul 20W-50 year round. I'm nervous about running synthetic in mine. I already have a small oil leak and not keen on seeing it get any bigger. Took it out again today and she ran a little hot but not like the other day. The needle was just a fraction above the 9:00 mark on the dial.
