-   -   HELP! Hub play after new bearing install?? (http://forums.pelicanparts.com/porsche-911-technical-forum/1164024-help-hub-play-after-new-bearing-install.html)
YellowBee69 07-08-2024 01:32 PM
Recently installed new wheel bearings and I’m 99% certain I didn’t damage anything. When I pressed them into the trailing arm I made sure to be touching the outer rim of the bearing, the retaining plate went on fine. I installed the hubs a few days ago with a hydraulic press, hub face down, and used a socket the size of the inner bearing race and pressed them in. Keep in mind the wheel studs were in the hub still. Face down on a flat 1/2” steel plate. Pressed in easy with the press however as soon as I felt ANY pressure at all I quit. They looked to be all the way in but honestly didn’t look super close. I got it all back on the car and there is quite a bit of play in my wheel. Is there a possibility I didn’t press the hub in all the way? Can I get it in the rest of the way using the axle/nut by torquing it down? Or did I flat out damage the bearing. I really took extra precautions installing them so I really don’t think that is the issue. But maybe I’m wrong. Any info helps. Thanks!
stownsen914 07-08-2024 02:15 PM
Are the stub axles in and tight? I’m not familiar with all models, but at least on some I believe this is needed to stabilize the bearing.
(And don’t lower the car or roll it around until the above is done.)
YellowBee69 07-08-2024 08:13 PM
I got home, and put my axles in and ran the nut down with my impact until it stopped, all play is gone! I figured I was overthinking it… thank you!!
