Which Cylinder Gets The Hottest . . .
I am hoping someone with some long term experience with the 911 motors, or even better 930s, could tell me which cylinder gets the hottest under WOT.
I am installing a combo CHT/EGT guage and am trying to decide which head I should put the sensor in. My guess is #2 (center left for those of you unfamiliar with the numbering system) to to the additional radiant heat that cylinder has to deal with. |
Information Junky
FWIW, I hear #3 (fwd left) is usually the first to cook when something goes awry.
(It is the furthest from the fan.)
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
I have also heard #3, but then again I heard it here, so if we all heard it from one source and that source was wrong...
But it does make sense.
Well, #3 would certainly be the easiest to tap for the probe unless someone has a differing opinion.
I heard front left is hottest, due to bad cooling...but it's somewhat balanced by the fact that OEM 930 intake is badly designed and flows more into center, so A/F isn't equal for all cylinders...
Thank you for your time, |
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
hehe...that's cool but i think that mounting thermocouples in air-injection holes is even more slick
I went with the pro act.. they do 1in. from the head for readings.. the SSI alows about 1 1/2in. .............Ron
I've heard the guys at Norwoods say #3 and #4 on a 930.
Those two cylinders are the most inline shot through the intake. Those two cylinders also seem to fail more offen. That's been the case on two of my race motors.
"Never go faster than you can stop" 85 - 930 (750hp) Norwood motec 3.5 twin turbo |
You know, i never thought that teleporting was possible, to instantaneously go from one place to another. But after reading Amac's signature with two 930s , one being 750hp, i think scientists aren't studying the porsches close enough.
2007 Mazda 3 hatch 1972 Porsche 914 roller with plenty of holes to fix
