banjomike's Avatar
Cool Got my cooler installed!!
It took the whole weekend, but I did it. During the early morning cool drive out to Modesto where the install took place, I was seeing it steady just over 210 (probably about 220). On the way home in the late evening I never saw above 210 (averaged about 195). I'm looking forward to getting a chance to give it a work out on a hot afternoon.
I took lots of pictures. I'll post some of the better ones tomorrow. By far the hardest part about it was that the lines were slightly out of kilter and had to be convinced into the right shape. I was thinking about writing up a tech bulletin about installing an external cooler on a car that doesn't have one, but that will take some time. Shout out to my Father-in-law who let me use his shop and lent me his experience and skills. And Kudos to all of the collective experience here that made me belive that I could pull this off!
Mike
Searching for a new ride
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
http://www.pelicanparts.com/gallery/BanjoMike
Old 06-22-2003, 11:50 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
Wuf! Wuf! Great job, don't it feel good to complete a good DIY project?
Enjoy it.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 06-23-2003, 03:12 AM
banjomike's Avatar
PICS of the project
jacked up
oil lines before
empty fender before
removed the rocker panels. Looked like a race car without the rocker panels, very cool.
to be continued....
Mike
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
Old 06-23-2003, 12:19 PM
banjomike's Avatar
PICS part 2
I hung the lines in there and sure enough they barely fit (needed some bending)
I got the thermostat to line up this way but trying to get a wrench on the nuts was a joke, so I took the whole mess out put it on the workbench, connected the thermostat there, and then put them back in.
After much fiddling with the various brackets trying to see how it snugs up, and making it fit, I drained the oil from the oil tank (had an oil change 2 weeks ago so I didn't change all of the oil or the filter) then I started on disconnecting the old oil line.
this wrench can only be used in one direction. (in this picture clockwise bad, counterclockwise good)
tune in next week, same bat time, same bat channel
Mike
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
Old 06-23-2003, 12:20 PM
banjomike's Avatar
PICS part 3
the trombone went on first, and this was no small job. The trombone required a fair amount of 'reshaping' to get it to line up.
here's where the new lines will go
and here they are
ain't that purty!
to be continued...
Mike
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
Old 06-23-2003, 12:22 PM
banjomike's Avatar
PICS part 4
some soapy water and this wasn't as bad as I thought it would be
put back together and filled up with oil, letting it run until those lines get hot (the gauge read just over 180 when they started to get hot)
stay tuned for the conclusion...
Mike
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
Old 06-23-2003, 12:24 PM
banjomike's Avatar
PICS part 5
couldn't have done it without his garage, tools, and help.
ready for the ride home
new cruising temp!
check that oil for the umpteenth time since yesterday evening.
All told I started by about 10am on saturday, worked until dark, started about the same sunday and was cleaned up by 7pm. Of course most of sunday was spent driving around the greater Modesto area looking for 1/4" 5/16" brass hose splice to repair the fuel leak (more like an extra spray nozzle just above the clutch linkage) I discovered when I started the car up. God knows how long it had been leaking but that is another thread.
I hope I haven't abused the bandwidth, I compressed and resized each of these photos.
Mike
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
Old 06-23-2003, 12:26 PM
Mike, great job. Thanks for the pics!
Warren & Ron, may you rest in Peace.
Old 06-23-2003, 12:32 PM
VincentVega's Avatar
Good work!
Old 06-23-2003, 12:55 PM
Silveresrty911S's Avatar
Great Job Mike,
Only a week or so to go and I'll be doing the same thing, only on my 3.2.
Thanks for the pics.
Rick
Rick
'76 Carrera 3.0, track
'77 3.2 targa, back home
'95 993 C4 M030, SOLD
PCA San Diego
Old 06-23-2003, 05:36 PM
Send a message via Yahoo to tmctguer
great job and photos. brought back memories of when i did that to my '73 911E. probably the best DIY job i've done so far. it was not cheap, but it provided much needed cooling relief for hot days at the track.
Old 06-23-2003, 07:59 PM
Somewhere in the Midwest
MotoSook's Avatar
Very NICE! Great job Sir Mike. WUF! WUF!
Old 06-23-2003, 09:42 PM
arrivederci's Avatar
If you spend any time at the track, you may be replacing the trombone with a radiator type of cooler. My '72 had temp issues (225+) at the track...my choices were to back off when the temp got up there or add an oil cooler. I chose to add a fender mount radiator cooler from a carrera.
Now, on the road, it'll get up to 180. At the track, though, it'll still get up over 210 when running hard on a hot day. I don't think that the trombone would provide the necessary cooling for a 3.0L on a hot day (based on the fact that I'm borderline at the track with my radiator style cooler).
- '72 911T
- '81 911SC Euro
Old 06-24-2003, 04:18 AM
Josh,
What size engine in your 72? Did you do any additional air routeing for the carrera cooler. I've got the heat sink type(14 brass tubes) and was wondering if that's the type you used.
Rick
Rick
PCA San Diego
Old 06-24-2003, 05:55 AM
My engine is a slightly warmed 2.4L T motor. It is running a higher compression, boosting HP from 140 to 170. I used the cooler from the later carreras. I know the brass tube cooler was used in '84...
The passenger side battery box (early cars had two batteries) was removed and air can now flow directly through my right side horn grill at the cooler.
Here is a pic of the installed cooler. Hope this helps.
- '72 911T
- '81 911SC Euro
Old 06-24-2003, 06:06 AM
Hey Josh,
What type of bracket did you use at the top of the cooler?
I've got an early car and am getting reacy to mount the cooler. I have the top bracket that came with the cooler kit but what did you mount that to?
Fritz
1987 944S
1973 911E
Old 06-24-2003, 07:07 AM
RETIRED
Joe Bob's Avatar
Parts Heaven gave me a REALLY good price on a NEW Carrera cooler. Since I already had the brass row one...minimal mods were needed.
Pelican has a complete kit with the rock guard and mounts as well....
2012 ML350 3.0 Turbo Diesel
Old 06-24-2003, 07:47 AM
I didn't install it myself...and I also haven't had to take it apart for any reason. So I'm not sure what was used to mount it. Sorry.
- '72 911T
- '81 911SC Euro
Old 06-24-2003, 08:31 AM
Chuck Moreland's Avatar
Fritz
The top of the cooler mounts to the back of the headlight bucket.
The factory setup is a metal bracket welded to the bucket. A rubber isolator connects the mount to the tab that is welded to the top of your cooler.
Chuck Moreland - elephantracing.com - vonnen.com
Old 06-24-2003, 08:58 AM
banjomike's Avatar
Your 'temp issue 'was my interim goal!! I have run it autoXing on a hot day and let me tell you that no external cooler at all was VERY INSUFFICIENT. I managed to keep it mostly under 250. I changed oil that tuesday. I vowed not to run it like that again until I had more cooling. My normal cruising temp on a cool day was just over 210. Getting hard into it even for just a few turns would get it up to 240 easy. I have not seen above 210 since sunday, though the weather has been very cool.
Since I had no external cooling, I was able to afford this as a staged project (and then only if I did the work myself). Phase one was to get all of the lines and thermostat to the front fender. Since the trombone was essentially free with the lines that was the obvious solution. Even with this compromise solution it cost me a pretty penny to get this far. This should keep the temp safe and sane through the summer commutes and autoXs.
If I had gone with a carrera cooler at this point that would have meant the two short lines, the cooler, rock guard, brackets, horn relocation kit, and the foam seal bit, which would have doubled my parts costs.
The next phase will be an upgraded cooler in the fender and depending on cash availability at the time the cooler fan may have to wait until phase 3. The next autoX in my region is in july and I hope to stress test it then.
Mike
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
Old 06-24-2003, 09:18 AM
