OIl tanks -- '86 vs. '73
I am putting a 1986 3.2L engine in my 1973 T. Can I use the original oil tank? Or do I need to use the 1986 oil tank that I got with the engine? If the latter, will it it fit Ok, do I need to cut any sheet metal?
I am using carbs so there are no issues re a sealed oil vapor return. I'd like to keep the original tank if it's not too much trouble. Thanks! |
Insert Tag Line HERE.....
The only issue you should have is the oil line connections, but those are easliy fabricated.
Marc |
Non Compos Mentis
I used the '87 tank from the donor car in my '73. Went right in.
