RSR high butterfly parts
dear pelicans
I'm looking for those parts please, any idea ? (1 lever )(in Europe would be nice !) Thank you Philippe
www.injectionsystemes.fr |
It's a 914 ...
There are some reproduction systems out there. You're probably already aware of them.
Eurometrix here in the US has had high butterfly setups and parts for years. They may be worth a call. |
No reverse gear in life
try mittelmotor. they make the reproductions. should be able to get you the parts.
David Alstadter - There is no reverse gear in life!!! 74 911 2.7 Carrera 9114400120 - licht grün 71 911T 9111121235 - recreated as 2.8 RSR glasur blau (3.0 MFI) 73 911S 9113301270 - silber metallic (sold) 72 911T - bahia rot (2.8 RSR) SCCA ITGT 95 LA & SD champ (sold) |
Eurometrix is probably your guy. Most repos use spiral shaft connector's, Matt went to huge expense to reproduce Solex shaft connectors, like I see in your pic.
Eurometrix doesn't sell separate parts ...
