nimrod
Help replacing windshield seal in CT or RI
Recently purchased a '67 912 from a 90 year old gentleman that owned it for 40 years. High mileage but amazing original condition. However, it needs new seal on windshield. I've reviewed the relevant info on the net. But I'm reluctant to start the job without knowledgable help. Anyone know of a skilled technician for hire in southeast CT or western RI? Alternatively, a P-car owner that has been through the process and might be willing to assist or keep me out of trouble? Thanks in advance. Tim in Stonington.
Try automotive associates. I went up and they banged out a reseal while I waited. Appointment, of course).
Ken 1986 930 2016 R1200RS |
nimrod
@gsxrken:
Thanks for the suggestion. I used them back in the early 90s when I had a '79 SC but I mistakenly assumed they only did mechanical work. I'll def reach out to them. Having some work done in Lakeville by David Rungee at Rungee911, and a stop in Canton would be ideal. |
PCA Member since 1988
The rear window seal almost certainly needs replacing too. Take it out, clean any rust out of the channel, and look under the package shelf for more rust. Stop the rust now.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
