Sway bar mount - welding question
Really two questions for the folks that have welded in new sway bar mounts:
1. How did you get down to bare metal on the chassis? Wire brush on drill, grinding disc, etc 2. How should I think about the chassis metal thickness as it relates to settings on my MIG machine. Any other pointers welcome. Appreciate it. |
PCA Member since 1988
I just scrape the undercoating off with a paint scraper, screwdriver, whatever works for you, and that will also scrape off the primer underneath. You don't need a lot of bare metal to get a good weld, and once you start your bead, the welding heat will burn off anything left on the surface. The hard part is the limited space you have to work in.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Racer
The hard part is that there is crappy weak metal there and just welding in a standard factory style mount will lead to the same problem down the road....
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
A scotch brite paint stripping disk on a grinder works good to remove the paint and undercoating without thinning out the metal significantly. If you are welding in the cast Wevo mounts aim the nozzle to direct the heat into the mount to reduce the risk of burning through. If they are factory style mounts make and add the little reinforcement plates (search for info). I've replaced these mounts on a few cars and they weld pretty easily. Body shops disconnect the battery and ECU when welding on the chassis.
New-ish 911SC Targa Owner
one of these on a pneumatic die grinder wil get into the crevasses and quickly strip away the paint and coatings leaving bare metal.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
Thanks Winders. I've had to sets of rear brackets rip off. I will try the torsion tube way with my 20mm Tarett rear sway bar.
I think I have .025 stainless steel wire in my MIG welder, using CO2/Argon mixed gas. I'll check it tomorrow.
And instead of cutting off the old bracket to weld on a new one, I used a piece of 4130 .0625" plate I had laying around to make a trapezoid brace that I formed to go on the inside of the original bracket. I bent the bottom edge into an "L" so that it overlapped the bottom of the existing brace. Then I welded the top of the brace to the top of the existing bracket, and tacked it onto the bottom face where the bolts attach the U-bracket to mount the sway bar.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 05-31-2024 at 11:48 PM.. |
Got link to "the torsion tube way?"
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Racer
https://forums.pelicanparts.com/porsche-911-technical-forum/930952-welding-rear-sway-bar-mounts.html
Thx
Racer
Wow! I haven’t looked in about 8 years…maybe you could do your own research.
Rear sway bar mount
I found them on FVD Brombacher for 175.00 each.
It's a 914 ...
If you weld, do clean down to bare metal. I use a wire wheel usually, but scotch brite and other similar products will work well I'm sure. While a welder will burn through the crud probably, that same crud will become part of your weld as impurities. For welding lawn furniture I wouldn't care. but for car suspension I do.
Re: wire size, I forget what you're welding to in this case, so I speak generically. If you are welding to sheet metal .060" or less, I'd go with .023" to avoid burning through. You can use .030" if you know what you're doing, it's just trickier. You don't mention how much welding experience you have. If this happens to be one of your first projects, you may wish to practice on some scraps you don't care about before welding your car. And I'll assume you've done your reading on how to protect sensitive electronics in the car while welding on it. |
I used Elephant sway bar mounts. I’m fortunate to have a pro welder for a friend who came to my garage to weld up the mounts. He had me drill multiple holes in the mounts to add more welding surface area. A clever approach I wouldn’t have considered.
![]() ![]() I prepped the area with a wire wheel to get down to bare metal.
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
Thank YOU! 🙌🏻 As luck would have it, I have a package from FVD en route rn. Who doesn't like paying shipping twice. So it goes.
Here are some surgery pictures that shows some of the sheet metal build-up on my '87. Not sure what thk changes happened over the years, but this car was two sheets of approx 0.025 thick material. It's not much. My car had been repaired twice with OE or the upgraded OE style brackets. Both broke for the PO. After the sheet metal repair I went with Tarrett's brackets.
There is a heat tube in there! ![]() ![]() ![]() My humble opinion: The Tarrett solution is the only solution that seems to solve the problem with the G and earlier 911 rear suspension design: The rear sway bar bracket will become overloaded over time as the spring plate or trailing arm bushings wear/sag. The Tarrett plate attaches to both the inbd/outbd sides of the body here and the torque tube which will prevent localized overloading of the thin sheet metal with a face only attachment. ![]() ![]() To prevent over loading, look into adjustable end links. On a street car, the bar should be neutral at normally loaded ride height. The OE set length end links prevent this as the car ages and the bushings sag. The end links will begin picking up more load as the spring plate bushings change and the distance between the trailing arm and sway bar mount shortens. As the load on the end link increases, the chances of the sway bar bracket breaking or attempting to tear off increase. |
Mine are going in soon. I find a good Afro wheel is the best thing to I get the grease, undercoating, and paint off. Good body guys use them by the ton. LOL
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
