1987 Carrera Power Seat Switch
My forward button will not work on the back rest control (other 3 directions do). I have ordered the part from our host and ready to install. I have removed the cover plate and have pulled the housing away from the seat however, I dont see how I can install without removing the seat. Is this possible?
If not, is it simply removing the bolts at all four corners? Would I be safe to just lean the entire seat back and swap out this switch or should I unplug everything and swap the switch on the bench?
Taking care of lots of fiddly items so stay tuned.
Old 07-22-2024, 06:32 AM
That's fond- just deglaze
Hi tx63conv- Here's a great post from '08...
https://forums.pelicanparts.com/porsche-911-technical-forum/412083-electric-seat-switch-replacement.html
Hope this helps. Also- removing your steering wheel first (using a 27mm socket) will minimize cussing & contortions.
Missed Approach
Petra- 1986 Coupe
Old 07-22-2024, 07:03 AM
Super helpful. Thank you. I love this forum.
Old 07-22-2024, 08:26 AM
