1000 miles @ 3700 rpm in 100 degree heat
I just drove my 82 911SC 1000 miles over 8 days in 100 degee heat at around 3700 rpm. I can really hear my valves compared to the begining of the trip. Will an oil change silence the valves, or will an adjustment also be necessary? Last one was around 7000 miles ago.
Thanks, Derek |
good question! I'd like to know the answer to that as well...
anyone?
Famous last words.. "Hold my beer and watch this...' " The reason the Irish are always fightin one another is that there are no other worthy opponents ". |
What kind of oil are you using? Just curious. At that temp and rpm I would at least use a good 20w50. 7k miles is half way to a valve adjustment. Thick oil can quiet a noise, but does nothing to fix the reason for the noise.
Good luck! |
drag racing the short bus
I notice a distinct difference in my valves in warm weather as opposed to not-as-warm (they're louder), but I don't worry as much. As long as nothing is really clattering, which I think you'd know and feel, and the car has its usual amount of power, things are good.
If the temperature gauge suddenly starts climbing, then I'd be concerned, or if the oil pressure dropped dramatically or was low to begin with.
The Terror of Tiny Town |
I just did an oil change with Castrol 20-50 and my engine, including valves, is much quieter now.
1987 Carrera, Guards Red, Black (sold but never forgotten!) 1965 356SC Coupe, Silver on Red |
anyway, I had a couple of exhaust valves that needed a tweak after about 14k miles on the big roads.. desert/mountains/etc... I only did the loose ones.. using the wiggle test.. then rode home from la la land.. and maybe big extended heat thins the oil beyond routine rides and thins the valve guide film/don't really know.. but I can relate.....................Ron
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Derek,
What were your oil temps during your trip? Do you still have the stock trombone or has the cooler been up-dated ? thanks, Chris 82 911SC |
I don't understand.
I thought as the valves wore, they seated farther down the exhaust/intake ports, lengthening the effective length of the valve stem and resulting in LESS noise, as the gap between the lifter and the valve stem closes. |
Interesting bill. Dangit, I'm so confused on the whole "what valves do when they fall out of adjustment". I've heard they get louder. i've heard someone say "they'd be so tight after that long [between adjustments]..."
What DO they do. Get louder and looser or quieter when they fall out of adjustment?
-kb- |
Kurt,
Valves can either get tight or loose. Tight can be a result of slight wear on the valve or valve seat. Loose due to the adjustment nut backing off slightly or wear in the valve stem or rocker. Remember that as the engine/valve gets hot, the gap increases not decreases. Tinker |
Super Moderator
I would think a slight amount of valve seat wear and also wear on the top of the valve would mean the valve would sit closer to the rocker, and therefore be tight...
Team California
Denis |
...Bruce |
Chris,
Valve seat wear results in the valve being sitting deeper in the head....increasing, slightly, the valve stem height and reducing the valve clearance, all things being equal. A greater clearance between the rocker and the valve stem or the adjusters would result in a greater valve gab. Maybe if they wore evenly, the net result is no change. I also thought that heat would cause the gap to decrease as metal expands, but it`s not so. The gap INCEASES. If you doubt me, check in any Haynes manual or owners manual that gives the valve clearance for both hot and cold. The cold value is usually less by approximately 0.05mm. Tinker |
Since the head is Aluminum or Magnesium it has a greater coefficient of expansion than does the steel valve stem. The head wins this little race so the valve lash gets greater with temperature.
Chuck Moreland - elephantracing.com - vonnen.com |
Team California
(In my best Col. Klink voice), "verrrrrrry interesting".
Denis |
PRO Motorsports
Chuck's right, except that it's more the cam tower expansion than the head, but I think he was including that as the head.
The valves do indeed either tighten or loosen, depending on what is wearing the most. The valves will tighten up if the valve face and seat wear, and will loosen if the rocker arm bushing, rocker shaft, elephant's foot, and valve stem tip wear. It all depends on the conditions inside that particular cylinder. Is it running lean, or rich. What type of driving it's being subjected to. The oil used, the fuel used, etc, etc, ..... It's very random on a 911, but on some cars, it's as regular as clockwork. Isuzu Trooper 4 cylinders will tighten up the exhaust valves completely in about 20K miles but the intake valves loosen. They didn't have the proper hardness in the valves and seats to take the heat of the exhaust. The intakes, cooled by incoming air, had no valve seat recession, so the other type of wear won out, and the intakes loosened up.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
