-   -   How to best test CSV? (http://forums.pelicanparts.com/porsche-911-technical-forum/1165313-how-best-test-csv.html)
PorscheCollecto 08-07-2024 03:27 AM
Hi Pelicans,
I need to test a CSV and want to do out the car. What's the best way to do this?
I assume it’s best to have the right fuel pressure while activating the 12V on the valve/injector.
Pictures and recommendation are very welcome.
Thx in advance.
BR
C
PorscheCollecto 08-11-2024 01:02 PM
No tiny helpful advise out there? ��
PorscheCollecto 08-11-2024 01:03 PM
No tiny helpful advise out there? 🥲
E Sully 08-11-2024 01:50 PM
To clean them I have used a syringe from a windshield chip kit and fuel line to the injector with mineral spirits and applied 12V.
In the past I have checked my injectors spray pattern with the whole CIS off the car. I connected a rubber hose the fuel pump inlet and put it in a gallon can of mineral spirits, and the return line into another container. That way I knew I had the correct fuel pressure to check spray patterns. I did it outside. I won't say it's an easy way to check it, but since I had the whole system off already it worked.
Since then I bought one of the injector cleaner testing pumps and it's a lot easier. Connect the injector to the pump, bring up the pressure and apply 12V.
Just a side note, I'm not sure what cold start valve you have but on the mine there is a filter screen in the inlet. I pulled them out carefully with a sheet metal screw and cleaned them.
http://forums.pelicanparts.com/uploa...1723409278.jpg
http://forums.pelicanparts.com/uploa...1723408918.jpg
PorscheCollecto 08-16-2024 04:10 AM
Thanks a lot Ed for the further details, that's really appreciated. I just got my CSV out of the car and will try to test it over the next days. :-)
If anyone has more information and/or good advices, please just feel free add them to the thread. All help are appreciated.
BR
C
boyt911sc 08-16-2024 05:30 AM
CIS Assistance………..
I could test your CIS components for FREE. I have a CIS Bench Tester that I like to share with people like you. Just mailed them to me and I will test them within 48 hours from receiving the package. Please include a RSL (return shipping label) preferably UPS. PM me if you are interested and will provide you the shipping address.
Tony
