47silver's Avatar
Spring plate angle calculator
Using elephant racings spring plate angle calculator to set on a 72T
One of the data points is car weight.
A T is 2315 pounds.
Should i add gas and body weight?
Old 08-10-2024, 11:29 AM
Somewhere around you is a weigh station. They are usually closed Sunday so you can drive over for free. Otherwise find a truck stop with a CAT scale and pay them to use. My guess is 2315 is with no persons and low fuel.
Old 08-10-2024, 12:45 PM
47silver's Avatar
Thanks good idea
Old 08-10-2024, 02:25 PM
PCA Member since 1988
My 1973T measured empty weight is 2330lbs, but it has fiberglass front fenders. With steel fenders, about 2350lbs. Don't worry about plus or minus 50 lbs of weight for your calculations.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 08-11-2024, 03:01 PM
47silver's Avatar
Pete
Thank you
Old 08-11-2024, 03:27 PM
