-   -   Trans support - Whst am I doing wrong (http://forums.pelicanparts.com/porsche-911-technical-forum/1165480-trans-support-whst-am-i-doing-wrong.html)
Quickstep192 08-11-2024 02:36 PM
I need to get the trans support bracket off so I can work on fuel lines.
My car is on a parking lift that has a lip that lets me place a 2x4 cross member to support the trans.
However, even when I get my temporary support really tight against the trans, the trans still drops down when I remove the support bracket.
What am I doing wrong?
Here’s a picture of the scene of the crime.
http://forums.pelicanparts.com/uploa...1723412127.jpg
Johnr352 08-11-2024 04:23 PM
I’m having a little trouble with the picture angle. Is the support close enough to the trans? Is the trans dropping at the bracket, meaning the wood is providing uneven support?
gled49 08-11-2024 04:30 PM
It is pretty heavy, I would expect it to sag. I’d be more concerned about getting it back up into place to re-start the 12mm bolts by hand. You need some jacking system to relieve the pressure completely.
Quickstep192 08-11-2024 07:15 PM
The picture is taken looking toward the back of the car. The support is about a foot back from the rear end of the tunnel. That’s kind of far back, but I need to room to work.
Here’s another picture looking straight up. http://forums.pelicanparts.com/uploa...1723429167.jpg
Quickstep192 08-11-2024 08:07 PM
It’s pretty easy to jack back up to install the bolts; I just can’t figure out why it’s dropping down. I took measurements and there’s no deflection in the support.
It almost seems that the support is acting as a pivot point and the part forward of the support is heavier that the part rearward of the support, but I can’t imagine that the trans weighs more than the engine. Can it?
ChuckleBeast 08-12-2024 04:43 AM
I think it's about 120lbs. Jack up a 2x4 directly under the bracket, remove the bolts and then let it rest on the temp support you've placed.
Paul Shugert 08-12-2024 06:14 AM
Sounds to me that the car/body is moving up
When the support bolts are removed.
Quickstep192 08-12-2024 07:57 AM
That could be since the car is sitting on a lift instead of the lift contacting the chassis
Is there a way to compensate/counteract that?
David Inc. 08-12-2024 08:23 AM
Going to have to jack or shim the trans up as you go, or put it all back on the ground and lift the car from the body and not the wheels.
pmax 08-12-2024 07:27 PM
Did you measure the fender height ?
Quickstep192 08-13-2024 08:06 AM
I did what ChuckleBeast suggested and the trans appears to be staying up.
How’s this look? Is this a good support point?
http://forums.pelicanparts.com/uploa...1723560396.jpg
ChuckleBeast 08-13-2024 06:49 PM
Looks good from what I can see. Be careful when bolting the mount back in to the chassis. You want to make sure you jack up the transmission again so you are not pulling it up as you are screwing the bolts in, easy way to strip the threads. I’ve sometimes found it helpful to have a second set of hand use a 2x4 to push lightly on the side of the transmission to line up the holes. Go slow.
