wolds's Avatar
CIS fuel line replacement
So over the winter I am replacing my fuel pump along with the fuel lines in the engine compartment on my 83SC. I am referring to the pressure and return lines that run from the chassis end points across the engine to the fuel distributor to be clear. I sent Len Cummings a picture of the lines which I have included here, but he is unsure as to if he can do them as he usually does the tunnel lines only. So how have all of you dealt with this issue on your cars? Warren
Lorraine 83 SC CAB RoW
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 01-12-2014, 11:52 AM
I'm sure Len could do these lines.........
Warren,
These fuel lines are not using the hard plastic fuel lines (Coline) like the ones used in the tunnel. They use fuel injection rubber fuel hoses and easy to replace. Using a crimper and the right size fuel injection hose/s are what you need. Send the old fuel lines to Len and I have no doubt he could replace all of them like OEM. Or have them done locally. Since I have access to a local shop, I have my fuel lines done locally. Otherwise, I will go to Len.
Tony
Old 01-12-2014, 12:49 PM
wolds's Avatar
Len's email sounded slightly apprehensive, but I'll get them boxed up and send them out.
Warren
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 01-12-2014, 01:35 PM
