-   -   Spacers on Fuchs? (http://forums.pelicanparts.com/porsche-911-technical-forum/116590-spacers-fuchs.html)
Bo 06-26-2003 10:52 PM
Spacers on Fuchs?
I'm looking to buy a set of used 21mm spacers to widen the rear track of my car - I have standard 16x7" Fuchs with 225 tires, and my Q is: will 21mm be ok or will the wheel rub against the fender lip?
Any one who has put spacers on their 84-89 Carreras? SmileWavy
Jeff Alton 06-27-2003 07:05 AM
I assume these are the H&R spacers? I just put a set on my 84 with 16x7 rears and 225 tires. They fit great. My car has been lowered slightly below the euro height and the tires do not rub at all- not even on the track on Monday!
Cheers, Jeff
Don Plumley 06-27-2003 07:49 AM
I put the 21mm H+R on my 87. Could probably go even wider.
Here are some before and after pics.
Don
1fastredsc 06-27-2003 08:45 AM
I've heard before that spacers can increase the rate of wear on your wheel bearing due to the extra leveraged force imposed. Could be wrong though, you think those would work on an SC?
Eric Coffey 06-27-2003 11:11 AM
On an SC/Carrera, 28mm spacers in the rear will fit nicely (no rubbing) with stock 7's. If you go with a bit more agressive camber (-1.8-ish), then you could easily go with the 32mm spacers.
