Red Koni adjustment on 911SC
Hi all,
I recently installed Red Koni's on my 911SC. I adjusted them to max. soft position in the hope I got the same comfort as the original shocks. When driving my 911 it feels a bit bouncy in the front.
What adjustments did you all choose to get a comfort but also smooth drive?
Thanks!
Old 08-24-2024, 07:44 AM
What year and how stock is it , is it lighter? or stock, wat is the weight in lbs.
If you just did front red koni classic inserts I start with full soft then turn one full turn in or 12 hrs ,
Then depending on how stock the weight is , stock gets another 4.5 to 5 hrs of turn in .
Thats how I make them work.
If you have rears set them full soft then 2-3 hrs in max .
The best results com from the classic red non gas . The Yellow can work very well also with very small adjustments 6 hrs += 1-2hr
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 08-24-2024, 07:51 PM
PCA Member since 1988
"Hours of turn in"?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 08-25-2024, 01:28 AM
It is a ‘81 SC. Everything is stock.
What do you mean by “hour”? 1 hour is just a very small turn?
Old 08-25-2024, 03:26 AM
One full rotation is 12 hours , just like on a clock.
With this reference it is easier to keep a record of your settings
Yes these are small differences in settings , it is important to do the adjustment in small increments .
Ian
Old 08-25-2024, 04:24 AM
1 hour = 30 degrees of adjustment screw rotation.
Old 08-25-2024, 06:57 AM
