Does lowering 911 front end require realignment?
My 77 911 ride height is 27" front and 25" rear (ground to wheel well).
I would like to lower front end 1.5". Will I need to do a new alignment? The usual advice is 25/1/2" front and 25" rear 25/25 just gives more nose down assuming front and rear tires are close to the same OD yes, realign yes, corner balance |
Not necessarily but it’s probably well advised.
Not necessarily????
At 1.5" lower? Yes, it will absolutely need an alignment. |
Also with Julian, not necessarily. I adjusted ride height to balance the car after setting toe, camber, caster. The balance, which changed the ride height, made the car track straight. Can't say this will happen with all rides, but as Julian also said check to be sure after. Most importantly is to maintain correct balance whenever messing with ride height. These cars are very picky with balance. You may lower the car and the alignment be off, but it's because you are now 3 legs long on a 4 leg chair.
The car will go from having some toe in to having toe out. Also, you are going to gain quite a bit of negative camber. You don't want toe out on a street car and too much negative camber will be problem too. Of course the corner balance is going to change. Of course the roll center in the front is going to go underground which will actually increase roll. |
Counterpoint Scott, maybe lowering the car will return it to proper alignment that was thrown off when it was raised…
All I’m saying is that it may not be necessary but probably a good idea to check. |
Terrible logic.... The car would have been aligned at the current ride height at some point unless someone raised it which is highly unlikely. It would be a terrible idea to not check the alignment. It's not like the ride height is being changed 1/8" here. The 1.5" change is HUGE!! |
If you lower an inch and a half, the critical thing to deal with would be the change in toe. That can be a DIY fix.
If corner balance is a concern the tripod method (also DIY) will get you close. Just my 2 cents. —Dave Sent from my iPhone using Tapatalk |
Yup, because every time a car is raised or lowered it gets a proper alignment: wonderful assumption. The point here is that the car should be checked now and after lowering to see what if anything it needs and then that should be addressed. It may need a lot, it may not. Nobody knows, least of all us idiots barking back and forth on the internet. OP; lower the car: there are plenty of threads on how to do it. The front is easy, the rear ain’t. Then check the alignment; again, plenty of threads on how to do that. It’s not terribly hard to align a car- it takes time, patience and a bit of tenacity. |
minor changes in suspension settings absolutely require checking alignment. Nuts to think otherwise
Love you, Scott. [emoji3590]
‘77 Spring Plates……..
Dave, Stock ‘77 911 does not have adjustable spring plates. Even with the adjustable plates, it would only make approximately a 3/4” max. height change. In order to achieve a 1.5” height change, you have to re-index your rear torsion bars. And could require multiple trials to get to your goal. The change in ride height to 1.5” is quite significant and the wheel alignment would definitely be affected. The final measurements should tell you what parameter/s need to be corrected/adjusted. The camber will be most affected by this alteration. Toe-In to be determined. Having an adjustable spring plates would make your job much easier. Good luck. Tony |
911 Ride Height
I heard American Porsches were raised 1”.
How much difference is there between European ride height an American? |
http://forums.pelicanparts.com/uploa...1725318030.gif |
911 Ride height
Hello
Sorry I didn’t mention my 911 is a 1988 Carrera Cab. |
An inch and a half is huge. Unless you've fixed the bump steer in a way similar to what I've outlined here https://forums.pelicanparts.com/porsche-911-technical-forum/1119373-bump-steer-check.html and have corrected the toe change so that it doesn't change through a few inches of travel, then yes, it will definitely need an alignment.
Agre with dannobee and winders: 1-1/2 inch drop is significant enough to affect alignment. Based on my measurements, the front wheel arch ends up about 26-1/2" when the front suspension height is set according to specs. Of course, that depends on wheel and tire combos too, but your 27" measurement sounds like it's higher than the spec right now.
Winders also mentioned the roll center. If you go lower than the stock height, the roll center changes to cause the front of the car to roll more strongly than the rear, which causes changes in oversteer/understeer. You also will reduce the operating range of the front shock, and you will be almost riding on the rubber bumpers in the shock, which will change the ride harshness. Proceed carefully and incrementally. Don't drop it the full 1-1/2" at once. Do it in 1/2" steps and test drive in between. Nditz1 mentioned corner balance. Listen to his advice. These cars are very sensitive to corner balance and will pull left or right, fooling you into thinking it's the alignment. Get the camber and caster set, then check the corner balance, especially if the car pulls slightly to one side. IMO, the "right way" to lower the front is to spend the coins to raise the spindles on the struts, or buy new struts with that feature. |
There's a thread over on Early911 about someone with handling problems with a 67. My user name over there would find it. I'm skeptical but here's the claim; OP cut 1" off of the shock rod and re-threaded the same. Thought about it and the only way I can think to do it is run a die down existing threads. Double nut the top to hold it for the die. Interesting idea and might work. My solution was short throw shocks with internal strut bushings. No need to raise the spindles.
Agreed 100% with the fellas who are being “idiotic” about the height change. The old 911 front suspension is very sensitive to height change. If you don’t reset the toe when you’ve futzed with the height, whatever was your previous toe setting has changed by a lot
http://forums.pelicanparts.com/uploa...1725453986.jpg The above is a graph from Porsche (provided by Bill Verburg many many years ago) that shows how the toe changes with front suspension movement. The vertical is height, the horizontal is toe. Trust me, the graph shows a substantial change in toe as the suspension moves. So when you change the static height of the car, you’re then making that toe change tht much more when the suspension goes up and down. This may not matter much to folks just driving around on the street, as they will never really notice it from a feel standpoint. But eventually your tires will show it to you. In a more telling situation, here’s a case in point of what it does at a faster pace. My buddy decided he didn’t like how his car looked and lowered the front to his visual liking. Next time we were at a track day event, he complained how his car was understeering like crazy. He’s a guy who was always faster than me but not today. I asked him what do you think changed, like are your track tires toasted? He says, well I lowered the front end. I said oh well there you go your toe is all out of whack now, you’re welcome. Reset the toe and all was back to normal, unfortunately for me….. Lastly, a long long time ago I rebuilt the suspension on my ‘87 911 3.2 and set the heights visually, then got it aligned. It seemed to drive fine, had fun with it at the track days. But man on corner exit in some corners It would lose grip and spin the inside tire quite a bit (open differential, not a limited slip) and I just thought that was because of the open diff. I drove it with that condition for a long time and just blindly assumed that’s just how it is. NOPE. A track day friend asked another friend (accomplished 911 racecar guy) if he could weigh his ‘79 SC on his corner weighting scales because he was simply curious how much it weighed. So we made a get-together out of it. I weighed my ‘87 Carrera to see how much fatter it was than the SC. What we also found was my right rear was about 300 lbs light. That’s a LOT. The car was basically like a table with a short right rear leg Point of sharing this is that I put a few turns of raising the left front suspension to see what it would do- transfer some weight to the right rear. What I should have done is work on the right rear but that’s more involved…... Shame on me but whatever. Wow what a difference next time on the track, even though I had compromised the toe. After that discovery, we set the corner weights to something decent (can’t get the weights spot-on ideal with the original Porsche fixed length sway bar links) and I got a full alignment with more aggressive camber settings. The car was transformed. It drove SO much better and felt much more stable My confidence also went way up because the car was easier to drive and my lap times were faster. ^^^ Take the above for whatever it’s worth. Just one dipshyt’s experience, shared on the internet |
Those saying "you don't have to re-align" are surely just having fun and pulling the op's leg, right? Common sense (to anyone familiar with anything suspension related), as well as simple grade-school geometry would prove without a doubt that there would be changes to the alignment with a 1.5" ride-height change without raised spindles.
Plus, how on earth do you verify the setup is symmetrical? By trusting a tape measure at some point on the fenders? This is all assuming the work is being done on level ground with a square and true car. Sometimes people just crack me up. Or do they just crack up trying to wind people up. OP, do yourself a favor and get that car aligned by an expert and reap the rewards of the improved driving dynamics. You might even get better tire wear as a bonus. I'm assuming you don't align cars, otherwise you'd just check and align after your ride height drop. |
A set of toe plates is a cheap tool and an easy, very effective way of resetting your toe accurately
The Roll Center Height affects the lever arm length causing cornering roll.
The only things that you can sortta easily adjust that affect roll center height are ride height spindle height The effect of lowering on RCH is illustrated here, an eyeball metric is the angle of the A-arm, the more down slope the higher the RC, the shorter the RC arm A, the less roll, it's just like using a stiffer t-bar w/o the bad side effects http://forums.pelicanparts.com/uploa...1725478443.gif The other separate but related thing to watch is the steering rack and steering arm heights 2 ways to adjust the steering arm height rack spacer (RS) adjustable steering knuckle this table shows the relationship between using a notional 10mm rack spacer(actual thickness is more like 11.5mm) and ride height, ideally to retain stock steering geometry the sum should be ~110+/-, an adjustable steering knuckle is only needed if the car is lowered to RSR height, ~160mm. http://forums.pelicanparts.com/uploa...1725478801.jpg |
It's a long thread but take a look. My ball joint photo is on page 11. OP's is page 1 or 2 I think which explains his problem. I defer to BV but there are other ways to skin a cat. Yes, stiff suspension. Roll, no. In other words my suspension compensates for the lower CG.
https://www.early911sregistry.org/forums/showthread.php?173561-1967-handling-problem/page11 |
For a little more on the concept--the roll center is the imaginary point in which the body tries to rotate (at that axle). The distance between the center of gravity (where side forces are applied) and the roll center is like a moment arm, so the higher the distance between CG and roll center the more torque there is on the body. With a wild enough roll center you could actually get the body to roll opposite to cornering forces, but everything else would be terrible. Interestingly, I saw in Formula 1 that at one point Ferrari had a neutral RC/CG at the front end to remove roll entirely. They stopped using it, though, because they were getting a ton of sideways movement at the front wheels under braking which upset grip (the wheels would move away from the body under braking load). |
http://forums.pelicanparts.com/uploa...1725559853.jpg |
Elastic: through the springs and shocks Geometric: through he suspension linkages The issue w/ geometric is it happens instantly, elastic takes some time as the springs compress, as the roll center is raised the ride becomes more harsh w/ a tendency to hop, F1 cars keep their roll centers low because of this effect lesson: you want roll center high bur not too high |
There's a lot to chew on when you start talking about moving roll centers around. Lowering the car will move roll centers around. Changing spindle location will move them around. So does moving suspension pickup points, like a 935 style suspension kit does.
As big or worse though is that when you move the suspension substantially away from its normal range, extraneous movements become more pronounced, like: - side to side movement of tires as they travel upward and downward (scrub) - toe change / bump steer gets worse - bottoming can be an issue when lowering the car Roll center changes can also become more extreme, but it becomes secondary to the above. As I believe David said above, the things that change roll center aren't always intuitive. The only way to really know where your roll centers are is to measure everything and map it. But it's not usually necessary to do it for a 911, as the mods that work are pretty well understood. If you play around with suspension modeling, one thing you'll quickly realize is that everything is a compromise, and getting the "optimal" setup winds up being very specific to a given set of parameters (ride height, tire/wheel sizes, etc.), and as soon as you change a parameter, you have to change other things to re-optimize. Raising the spindles addresses the issues pretty well in most cases when lowering a 911. 935 suspension kits take it a step further. |
also remember the factory specs for street 911 ride height are +/-5mm, there is a 10mm range for all the values associated w/ it In other words I wouldn't worry about it too much |
I've always understood the 935 style kits move the rearward A arm mount inward. And possibly upward as well. (Can't speak for the ERP kit specifically.) Moving suspension pickup points definitely moves roll center.
| All times are GMT -8. The time now is 01:42 AM. |
