1977 911S
Are these plugs available separately ?
![]() I’m looking for one of these screw hole plugs which I’m missing in the attached photo Also interior screw hole plugs for the door card on the upper section. Are these available on Cork? I can only find black. Last edited by SpenceRx; 08-29-2024 at 12:31 AM.. |
yes you will finds them on the PET
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
lake wales fla
Try 914 552 233 10 O1C
“Also interior screw hole plugs for the door card on the upper section. Are these available on Cork? I can only find black.”
I don’t think these door panel card plugs are color matched if your door handles and side pocket lid are black. The PET for the sill cover and card panel denotes a color/material whereas the plug does not. Maybe there’s a similar hole plug found on more modern cars that are appealingly particular with color matching interior bits. Dorman products might be a source. But you can always paint the plugs with Dupli-color vinyl spray to somewhat ubiquitous beige flavor, no close match but less contrasting than black. |
