Part # or specs help
Looking for part # or specs, please. Anyone can help with part #? I could not find on our host products search, scrolled thru 20+ pages.
Or, if you know the specs -- material, thickness, ID & OD, perhaps I can buy one @ HD? The washer that goes on the rolling pin holding the brake pedal and MC/Booster linkage together. See below --- I nicked a few fotos from Jose Martinez via his Blog to illustrate the part I'm looking for. While trying to reassemble the linkage, the washer fell under the pedal cluster --- I don't want to remove it. I'd rather just buy a new one. Thanks!!!! http://forums.pelicanparts.com/uploa...1725061566.jpg http://forums.pelicanparts.com/uploa...1725061566.jpg |
Porsche part no. 900 031 005 02
Washer 10,5mm diameter (hole) Standard part, zinced steel, nothing special. The bolt is 10mm thick. For such investigations the Porsche PET parts catalogue is the source: https://www.porsche.com/international/accessoriesandservice/classic/originalpartscatalogue/ Thomas |
Thank you for your prompt response, Thomas! Appreciate you sharing the part #, dims, and the PET link.
I made a trip to HD. There weren't many choices for metric washers. So, went w a 3/8" washer. Re-assembled the linkage, and also got the accel pedal back into the ball rod. A bit of liquid soap, locking plier to hold the rod steady, and tap on the pedal face w mallet did the trick. Start early tomorrow AM to bleed the brakes w new MC. Quote:
| All times are GMT -8. The time now is 03:33 PM. |
