Timing Chain Rattle? Or something else.
Hi, thought I would check in with smarter people here. Chasing a metallic grating sound on start up after idle slows down. Brain jumps to a failed tensioner as the possible culprit. But everywhere I look it is equated to a chain on a garbage can or oil drum sound. To me, this doesn't match that, and no one seems to have a recording of the sound.
Link to a recording, sound starts at 10 - 15 seconds and has brief louder moments. https://photos.app.goo.gl/mTL3Rb659Zz9NvdCA That sound like failed tensioner?
88 Carrera Cab |
Check you amount of shims at the alternator adjustment must be 6.
.Also if you do not have stethoscope use longer screwdriver one end goes to you fist and year and the other place on top culprit are..it will point it where the noise most likely is Alternator is a little bit whining -possibly bearings Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Yes, maybe run it for 20 seconds without the fan belt attached. To me it sounds like the alternator bearing or thereabouts.
You can take the belt off and spin the alternator / fan by hand as well.
Here's what an old, dry, worn out bearing sounds like. https://www.youtube.com/shorts/ImgCNNnkny0 |
Thanks for the input. Took the belt off and ran it for 30 seconds. Hard to pinpoint sound as it goes away after 15 - 30 seconds. Fairly certain it is coming from right side. Heard it just once this time and putting a stethoscope to the right chain cover, it didn't happen again.
88 Carrera Cab |
try to do another video ..just point it to the right side.You can run the car more then 30 sec without the lat belt...even a minute nada will happened;-)
Ivan
