-   -   Classic retrofit fuse box (mini fuses) (http://forums.pelicanparts.com/porsche-911-technical-forum/1166699-classic-retrofit-fuse-box-mini-fuses.html)
SFR 09-06-2024 06:07 PM
I just bought one of these from Audette and I don’t think it’s working properly.
Bottom line, the LEDs never light up.
It there a re-set or something that needs to be done to get them to work.
I’ve seen videos where they light up when you turn on the directions or have blown fuses…I get none of that.
The panel is working as everything in the car works.
Help (I have emailed Audette for info, nothing yet).
mikesarge 09-06-2024 08:32 PM
There is a switch on the fuse panel that you need to move to turn it to ‘test’ mode, I’m assuming you’ve found that though yeah?
SFR 09-06-2024 08:52 PM
Mike - I have not seen the ‘test mode’ switch, where is it?
gerakroo 09-06-2024 10:32 PM
I don't think the fuseboxes John is selling are the Classic Retrofit ones ?
famoroso 09-07-2024 02:08 PM
If it is, in fact, a Classic Retrofit panel, aren't the LEDs fuse *failure* indicators?
If you pull a fuse (emulating a blown fuse / opening the circuit), does the corresponding LED light up?
spuggy 09-07-2024 04:21 PM
Yup, red LED above the fuse. Only lights up when the fuse is blown/removed AND you're trying to operate the circuit.
The Audette fuse box has a two-color (red/green) LED below the fuse.
Red LED for fuse blown, Green LED for output live, Green LED when fuse removed, and backfeed is present.
Another way to tell is that the two relays are one above the other on the CR fuse box - looks to be two relays side-by-side on the Audette.
Classic Retrofit:
http://forums.pelicanparts.com/uploa...1725751043.jpg
Audette:
mikesarge 09-07-2024 06:35 PM
In the pic right above, see the bottom left corner, that little red piece next to the bottom post for the left-most fuse is a switch that turns on test mode
SFR 09-08-2024 06:09 AM
Mike - that’s it, now it works.
Thank you.
gdp_samson 09-10-2024 01:55 AM
SFR, you were happy with the installation ? tight fit for multiple cables or everything went smoothly ?
SFR 09-10-2024 11:38 AM
I was happy with the install; yea some of the wires were tight, but overall it was fine.
