So....additional edit now: . I will need to add approx. .3 mm on metal into the groove on the hub at the deepest point. I did my first practice welding tonight. So practicing on the old pulley, I was able to build up at the above depth on a small experimental area. The practicing weld looked rough, black and bumpy. However, it feels quite strong. My main idea here will be to be able to file down the additional fill so the added fill will be smooth to receive the new pulley. I would prefer to work on and off on the final weld for a few days. Would the strength of the new weld, on the hub be affected, were the welding be done off and on for a number of days? |
You should be able to leave sit with no adverse effects. It sound like you are useing a cored wire which always looks bumpy and overall kind of crappy. They are still strong but just not as pleasing to look at. As far as filling just fill up beyond where you need to and then file down . you should be good to go.
Ben |
| All times are GMT -8. The time now is 02:56 PM. |
