-   -   No Accelerator Jets after long layup (http://forums.pelicanparts.com/porsche-911-technical-forum/1166824-no-accelerator-jets-after-long-layup.html)
Quickstep192 09-09-2024 01:24 PM
Started the car today after a 2+ year layup. 40IDA Carbs were drained before layup.
After resolving some stuck float issues, I noticed that none of the accelerator jets on either side are working.
What’s the most likely cause? The jets themselves don’t seem to be clogged.
john walker's workshop 09-09-2024 01:58 PM
The accelerator pump diaphrams can get hard.
Quickstep192 09-09-2024 03:01 PM
Obviously it’s been a while since I’ve worked on my Webers. Where does one get parts these days?
john walker's workshop 09-09-2024 04:41 PM
Pierce Manifolds for one. Parts Klassik.
LuftWaffle 09-10-2024 09:29 AM
Just went thru something similar when installing a pair of Webers that I rebuilt a few years ago but just got them back into service. Mine turned out to be a stuck check valve in the float bowl that supplies the accelerator jets circuit. Agree with John on Pierce Manifolds - great to work with in my experiences.
Quickstep192 09-10-2024 11:09 AM
It’s been a while since I’ve worked on my Webers so I’ve forgotten a lot.
Can you describe just where the check valve you’re referring to is located?
john walker's workshop 09-10-2024 12:33 PM
Bottom of one of the float bowls. Take the float out to see better.
john walker's workshop 09-10-2024 04:17 PM
http://forums.pelicanparts.com/uploa...1726010177.jpg
Quickstep192 09-10-2024 05:19 PM
Thanks very much for that picture.
I’m wondering if I should just plan on replacing them?
930cabman 09-11-2024 04:11 PM
They aren't that difficult to tear down and rebuild. Get the kits and spend a couple hours
Quickstep192 09-11-2024 04:41 PM
LOL. I meant replace the check valves, not the carbs :)
I’ve rebuilt them before.
Do you guys think removing the carbs from the car makes the re-build that much easier? My car is on a lift so I can at least get it at arm level. Still have to lean on though.
Locker537 09-12-2024 07:13 AM
Absolutely remove the carbs to do a rebuild.
If you want to replace the accelerator pump diaphragm only, you can do that without removing the carbs from the engine. Quick and straightforward.
Quickstep192 09-12-2024 02:16 PM
I’m debating about whether or not to do a re-build.
The car has been sitting for three years. It runs, but lots of backfire and as the title of this post suggests, the accelerator jets don’t work. Sometimes if feels like a re-build would be a cure-all, but I’m feeling lazy about putting in the work!
PeteKz 09-12-2024 03:14 PM
If you let it sit for 3 years with ethanol-contained gas in it, You most likely will end up disassembling it to clean out the green crud.
You can do it now, or you can do it later...
john walker's workshop 09-12-2024 04:03 PM
No accel jet function will certainly cause lots of backfiring, as well as too small idle jets, improper mixture adjustment, retarded timing, etc.
